iCue Software integration issues
ALIENICECOOLER
If you have a Asus Maximus Extreme XI MB and Vengeance Pro rgb ram and are having crashes or glitches or non responsive lighting with the Ram please uninstall the Asus Aura.
1. The Aura software is no longer needed.
2. The RGB on your motherboard will work with iCue (give it a few seconds to a minute to initialize)
3. ITS ABOUT DAMN TIME!!!
BigJohnny
Mine was working then a BIOS update and a firmware update to the AURA on the MOBO and Ique no longer sees the MOBO, Neither does armory crate. I shut down all of it and try launching aura on its own through several of the latest versions and this is what I get every time. 84200
I just connected everything I can to Corsair and what cant be I leave on the MOBO default. Only choice as nothing will control it now.
