fan /temp monitor/controller for Rampage IV
bwana
I think this mobo had AI SUITE 2 back in the day. Cant find it tho. What's the preferred way to quiet the fans from the desktop?
Intel 3770K 4.4ghz, 1.24v. . . . . . . . . . . . . .Intel 4930k 4.7ghz 1.37v........AMD 7800x3D async 104
32 gGSkill DR3Trident 2400mhz 1.65v. . . .32 g 1866 Vengeance Pro.......64 g Hynix 6200
ASUS M5G. Noctua D14. . . . . . . . . . . . . . . H110. Noctua A14x4.............Arctic 420
prime95 stable 78degrees. . . . . . . . . . . . . IBT 75 degrees
OCZ V4 OS. . . . . . . . . . . . . . . . . . . . . . . . . EVO 1TB...............................WDSN850x 2TB
Seasonic 700w. . . . . . . . . . . . . . . . . . . . . .1200AX.................................HX1200i
All tucked into Lian Li A05. . . . . . . . . . . . . .Fractal Midiv2......................BeQuiet802
davemon50
Level 11
AIS2 is available online on the support page for that board. However, it's not certified to W10, only previous versions. If you change the Windows version in the dropdown you can download it.
Davemon50
Thank you. FYI, I did try AI suite 3 and it seems to work fine, including fan expert2.
