Results 1 to 3 of 3
    ROG Junior Member Array Dinosdad PC Specs
    Dinosdad PC Specs
    MotherboardAsus ROG Strix Gaming E X-570
    ProcessorAMD Ryzen 3800x
    Memory (part number)F4-3600C16D-16GTZNC
    Graphics Card #1Sapphire nitro+ 5700XT
    Storage #1PNY 240GB m.2 NVME
    Storage #2Intel 660p 1TB
    CPU CoolerDeepcool Castle 240 RGB
    CaseNZXT H510
    Power SupplyCorsair RM850x
    OS Windows 10 Pro 64-bit
    Nov 2012
    1
    Network Adapter Issue
    Hello all,
    Two weeks ago I build my new system. Today my internet connection was upgraded to 100 Mbps. My issue is this. Although i can reach the 100mbps through any other device (laptops, other pc) with the new one the speed is throttled to around 20 mbps. I changed cables, ports, uninstalled, reinstalled drivers nothing changed. I tried a wireless connection as well. I tried the intel port and the realtek port on my motherboard. Still nothing. I am sitting here busting my head trying to figure out a solution. Is my motherboard faulty? Are the drivers messed up? Please if anyone can find some time to help me out i would really appreciate it. Anyways thank you for your time and please forgive me if my English aren't good enough it is not my native language.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    301
    7,628
    One way to test for a hardware fault would be a different operating system on a bootable USB stick. You could boot Ubuntu without installing it and run a speed test. If that works then you know it may be an OS or driver issue.
    FWIW, I once had an issue with an Intel ME driver killing my connection. You wouldn't have the same issue on an AMD system but be aware it might not be the network adapter driver itself at fault.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Yellow Belt Array SaLSouL PC Specs
    SaLSouL PC Specs
    MotherboardCrosshair VI Extreme
    ProcessorRyzen 7 2700x
    Memory (part number)trident RGB CL16 3200mhz 32GB
    Graphics Card #1MSI Gaming 6GB GTX 980Ti
    Graphics Card #2MSI Gaming 6GB GTX 980Ti
    Sound CardAstro A50 Wireless
    MonitorPhillips BDM4037U 40" 4k UHD Monitor
    Storage #1samsung 850 pro raid 0
    Storage #2WD Black 1tb Raid 0
    CPU CoolerCorsair H115i
    CaseCoolermaster Cosmos 2
    Power SupplyCorsair ax 1200i
    Keyboard Corsair K95 Platinum
    Mouse Corsair Scimitar RGB Pro
    Headset Astro A50 Gaming Wireless
    Mouse Pad corsair massive
    OS Win 10 x64 pro
    Network RouterAsus AC-3200
    SaLSouL's Avatar
    Mar 2012
    13
    230
    Quote Originally Posted by Dinosdad View Post
    Hello all,
    Did you install "ROG Game First V etc?" if so chances are that it is this.
