Results 1 to 5 of 5
    New ROGer Array
    Oct 2019
    2
    Advice regarding WiFi antenna
    Hello
    I have recently made mini-ITX build using the ROG STRIX Z390-I GAMING motherboard.
    One thing which has been a focus for me is a very minimalistic computer and desktop, with as few cables as possible - and here comes my problem:
    I am very sad about the cabled WiFi antenna extension as seen on this picture
    I would much prefer to just have regular antenna that stick out on the back of the motherboard.
    But does anyone know if I can just buy any regular antenna with the right connector? Do I need a special antenna to boost both the WIFI and the bluetooth, like the cabled antenna which came along with the motherboard?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,754
    The threaded connectors should work with a standard antenna but your signal strength may not be as good. It depends on where your access point is located.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Oct 2019
    2
    Thank you for the answer. Do you know if a standard antenna would boost the bluetooth signal as well? or only wifi?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,754
    Interesting question. Never thought about that but I doubt you'd see a significant difference. It's designed to be low power and short range. The main reason I doubt you'd see much range difference is that it is 2-way communication and no matter how you upgrade your PC the paired device will still only be able to transmit so far.
    New ROGer Array
    Jan 2020
    26
    I have no idea what the connector is for the Asus supplied WiFi/Bluetooth combo antenna is. Seems like to me that if you can find another with same connectors, it might be worth a try. https://www.amazon.com/Directional-A.../dp/B01MDJVPTT
    Another thought. If you were to tear open on of those Asus antennas, you'd find the length of wire that is needed for the WiFi/Bluetooth frequency. After all, regardless of the fancy or bizarre style, an antenna is just a hunk of wire that is the correct length for the frequency. Build your own: http://www.hamuniverse.com/dipivcal.html
Tags for this Thread
