Results 1 to 3 of 3
    New ROGer Array
    Mar 2020
    2
    Asus G731G - Problem with Nividia RTX 2070 Graphics Card
    No matter what I do, I cannot get this card to work.
    I get a "Windows has stopped this device because it has reported problems. (Code 43)" in device manager.
    I tried DDU'ing out the old NVIDIA drivers and reinstalling the ones from Asus, but that did not work.
    I tried to reinstall a fresh copy of windows, but that did not work, either.
    Luckily, I bought this from MicroCenter only a month ago, so I could get a return and a swap, or it can be fixed under warranty.
    Has anyone had experience with these cards?
    Is it a hardware problem, or should I try something else with the drivers?
    I couldn't even load the NVIDIA control panel to test the card.
    ROG Guru: Orange Belt Array
    Nov 2014
    8
    263
    I would advice to replace your laptop under warranty. Almost 100% sure that you have the bricked/fried graphic card.
    And the only reason you see anything on the screen is that the other GPU Intel UHD Graphics is still working ok.
    New ROGer Array
    Mar 2020
    2
    Quote Originally Posted by Sanctrum View Post
    I just returned it, but I wanted to say that MicroCenter has a good return policy.
    They tested it, and told me that I could get a replacement right away.
    They didn't have to send it to Asus first as they are already an authorized repair center for Asus.
Tags for this Thread
