G715GV CPU 100% ingame with 70°c Temp
Julianinho99
On my G715GV , when i play "rise of tomb raider" i have throttling on my cpu for 2 secondes, it block to 100% use.
The gpu is 70 fps with 60% use
The temperature is:
cpu : between 65°c / 70°c
gpu: 70c
I have disable turbo boost on settings windows and i have undervolt cpu at -150mv.
My cpu is: i7 8750H
Thanks
Best regards
Budton
Hello!
I have the problem but i don't undervolting because the bios as blocked.
Can u give me your bios?
Thanks
Nate152
Hello Budton,
Those temps are within spec and quite good for a laptop.
What are your cpu and gpu temps?
