Results 1 to 1 of 1
    ROG Member Array
    Sep 2013
    21
    swapping out ryuin fans with aura sync rgb and speed controls support
    hi i want to replace the radiator fans on the aio oled asus cooler to fans with rgb will i get full aura sync support if i connect aura sync compatible fans the same exact way that the noctua fans are connected as in one cable exactly the same way as the stock does it work like that.
