Results 1 to 6 of 6
    New ROGer Array TheFifthPillarMan PC Specs
    MotherboardAsus GL12CM
    ProcessorIntel® Core™ i5-8400
    Memory (part number)CMW16GX4M2C3000C15
    Graphics Card #1MSI GeForce GTX 1660 SUPER VENTUS XS OC
    Sound CardRealtek® ALC1150
    MonitorHP 22f 22-inch Display
    Storage #1Samsung 860 QVO 1TB SSD
    Storage #2Seagate Barracuda 1TB HDD
    CaseROG Strix GL12CM
    Keyboard MSI Vigor GK30
    Mouse MSI Clutch GM11
    Headset Astro A10 The Legend of Zelda Edition
    Mouse Pad Razer Sphex V2 Mini
    Headset/Speakers Logitech Z313 Speaker System
    OS Windows 10 Home
    Mar 2020
    4
    Corsair RAM speed issues on GL12CM
    Hi there,
    I recently decided to upgrade a my ram with 16gb of corsair vengeance rgb pro clocked at 3000mhz but unfortunately the ram only clocks at 2133Mhz.
    I've tried searching for an xmp profile in the bios but couldnt find one there so I tried updating the bios to see if it would appear then but still no such option has appeared.
    My PC is an ROG Strix GL12CM with a motherboard with the same name.
    Please ask me for any more details but would love some help on this as I'm still fairly new at stuff like this.
    Super Moderator Array
    Jan 2013
    121
    2,290
    Welcome to the forums!
    Unfortunately, it doesn't appear the GL12CM supports XMP, so you might consider exchanging or getting a refund for your memory if necessary, but also sounds like it may not be compatible with your other memory or maybe the system.
    If you remove the 16gb of Corsair Vengance RGB Pro memory, does the original memory show the correct speed at least and have you tried running the Corsair memory by itself to see if that makes any diference?
    Unfortunately, we don't normally approve many upgrades for these systems sold complete, so hopefully other members can share their experiences to give us a better idea.
    OS Windows 10 Home
    Mar 2020
    4
    Hi thanks for getting back to me.
    I did try what you said with running only the corsair ram but it still only clocks at 2133Mhz. Oddly enough the bios does show that the ram has xmp revision 2.0 but nowhere to enable it.The original ram also would clock at 2666Mhz when it was installed by itself too.
    Im guessing the only solutiin would be to get a new motherboard that can use xmp profiles. Any suggestions?
    Once again thanks
    ROG Guru: Green Belt Array
    Feb 2019
    129
    692
    To my knowledge no ASUS laptop is capable of anything past 2400 so buying anything rated higher is a waste of money. Best laptop ram I’ve seen is Gskill ripjaws 2400 in the lowest cas you can find. Already been down that road with a G752VY and forced it with XTU.....HUGE mistake! Do you know where they put the CMOS battery in those? *Yep complete disassembly to recover.*
    Jan 2013
    121
    2,290
    Quote Originally Posted by TheFifthPillarMan View Post
    Once again thanks
    If your corsair ram only runs at 2133Mhz by itself, doesn't sound like it runs well with this system unfortunately, although if possible, you might try to make sure it runs faster on a different system to confirm the memory is ok.
    Since the original memory is running at 2666Mhz by itself though, guessing it may work better if you can find the exact same kind of memory to add, or maybe similar/compatible memory if you want to just try more memory?
    Unfortunately, don't deal as much with upgrades in these systems sold complete, so you may want to try to talk to more people about it (or hopefully get more feedback on the ROG forums), but if you have a store you trust, you may want to either check if they can sell you some memory that will work better, or maybe ask them to test and install it in your system for you if you would rather not replace the motherboard.
    Alternatively, you can try to talk to some memory manufacturers for recommendations. There are probably others you can check with, but in the U.S. Crucial will list memory they have approved on their end for the GL12CM as below although it hasn't been checked or approved on the ASUS end, so you would need to deal with them if you run into any issues and don't know if it would work with your original memory, so you might need to replace it too.
    https://www.crucial.com/compatible-upgrade-for/asus/rog-strix-gl12cm
    Again, don't know a whole lot about it, but have seen someone suggest trying to match the same timings as your original memory if you want to look into that and wondering if it's a good idea to use memory that supports XMP or not on this kind of system, so something else to consider.
    Last edited by cl-Albert@ROG; 07-27-2020 at 05:07 PM. Reason: change crucial memory link to GL12CM from GL12CX
    New ROGer Array
    Sep 2020
    1
    Once again thanks
    I found the same issue with some HyperX Fury 3200MHz ram. The mobo clocks it at 2133MHz. In my case I bought the GL12CM mobo with i5 8400 processor together very cheap used with no ram, so I can't really complain, I still got great value for money.
    However if I had bought a Asus GL12CM new I would be really annoyed. Asus market the PC as upgradeable. Surely swapping ram is one of the most basic upgrades you can make? Asus should update the mobo bios to give their customers exactly what they paid for - an upgradeable gaming PC.
Tags for this Thread
