PG278Q Monitor doesn't work with USB-C-to-DP cable
Talwyn
I have this PG278Q monitor and a USB-C-to-Displayport cable, running from a Lenovo X1 Carbon 7th gen with USB-C/Thunderbolt3 ports, but I can't seem to get it to work.
I can see in the monitor specs that HDMI-to-DP adapters aren't officially supported by Nvidia and rarely works (found in my search one exception with an active adapter (w/power)), but it says nothing about using one USB-C-to-DP cable (it's not an adapter, though I suppose it might work like one).
I can find several different cases where an Asus monitor worked with such a USB-C cable, even when it wasn't specified that it was supported, though nothing about my own specific model. I'm aware that G-sync won't work, but that's irrelevant to my case.
My laptop is fully updated with both newest bios, drivers and firmware (drivers/firmware for USB, thunderbolt and monitor included), USB-selective suspend is disabled, nothing in my BIOS is disabling the feature.
I'm guessing the monitor doesn't support USB-C-to-DP, but I'm hopeful and reaching out for solutions anyway.
Hope anyone can help!
8 REPLIES 8
xeromist
As far as I'm aware there is no special requirement on the monitor side. With a compliant Thunderbolt device and TB>DP cable you would be sending a standard DP signal compatible with any DP display. It's literally part of the TB spec that it uses the DP standard.
So my guess is that you have a bum cable or you are using a USB-C port without TB support. Some laptops have both so make sure the port you plug into has the lightning bolt next to it.
Talwyn
The X1 doesn't have any USB-C ports that don't also support Thunderbolt3, though I've tried all ports just in case. As annoying as it might be to have a bum cable, at least that might mean there's still hope. Thanks. 🙂
The cable is 2m long, so perhaps I'll have some luck buying a shorter one, of a different manufacturer.
Anyone else out there have anything to add? 🙂
Talwyn
Unfortunately, buying a shorter and higher quality Moshi USB-C to DP cable didn't help. It refuses to detect the monitor, though it finds the cable just fine. Anyone else out there with advice?
xeromist
The only other thoughts I have is check with Lenovo to see if they have any recommendations and if your area is not suffering an outbreak see if there is a friend or local shop with a monitor you can plug into. That would help narrow if the monitor is failing or somewhere else in the chain.
Talwyn
I've tested on several DisplayPort monitors. The laptop works on all of them with no trouble at all. I also contacted Asus customer support, and if I'd updated my drivers, they couldn't really help me with anything more. They suggested it might just be a compatibility issue. 😞 Looks like I'm not getting anywhere on this one.
Pheolix
Are you running the monitor in 165Hz-mode or plain 144Hz? I have had similar problems myself where the thing started workin when I set the display input to 60Hz. In my case it worked up to 120Hz, but not higher, which was due to the cable itself.
Talwyn
My model has 144Hz max, but setting it at 60Hz did not help, unfortunately. 😞 Any other ideas?
Talwyn
Yay! :cool: I made another attempt by updating to Intel's newest drivers, and it worked! They are not (yet) officially supported by Lenovo, so I had to do a manual install, but the result is glorious! 😄 120Hz is max, btw, and 144Hz gives you a black screen.
