Results 1 to 1 of 1
    ROG Member Array
    Jun 2016
    5
    Solved - G750JW Realtek Audio Level Jumping
    After years of trying to find a solution to fix loud audio level bumps when playing/pausing video and music files I have finally found a fix! Go to device manager, flip the arrow open next to "Sound, Video and Game Controllers". You'll see:
    1. High Definition Audio Device
    2. Realtek High Definition Audio
    Right click on #1 High Definition Audio Device and select "Disable". Don't uninstall it will just reinstall and the problem returns.
    Leave it disabled, problem solved!
    Regards,
    Terry
    Miniatura de Adjuntos Miniatura de Adjuntos G750JW Audio Level Jump Solved.jpg
