Results 1 to 9 of 9
    ROG Enthusiast Array
    Mar 2014
    28
    Zenith II Extreme the new BIOS 0902 higher power consumption than 0802
    I flashed the new BIOS version 0902 and with this BIOS and the same setting as with version 0807 PBO enable the CPU 3990x with the new BIOS will boost to a lower frequency (3.5GHz) than the 0807 (3.9GHz) and consumes higher power.
    Is ASUS continuing to sabotage this motherboard BIOS to force more customers to buy the Alpha.
    Anyone with the Alpha can test whether the new BIOS behaves the same.
    Also the 3990x memory problem is not fixed.
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,666
    Working well here with 3960X...will try 3970X
    Jan 2012
    13
    45
    PBO seems to be working the same for me on the Alpha boosting to 3.65-3.7 under full load just like it was on 0807. I am actually surprised you are able to get PBO working on the non alpha I was never able to get it stable when I turned it on. It would boot into Windows just fine, but any load would cause the machine to reboot.
    Mar 2014
    28
    What about the power consumption, do you see a difference?
    Jan 2012
    13
    45
    nope power consumption is the same 500-520w for the cpu.
    ROG Member Array
    Jun 2016
    I'm still on 0702. I've been keeping an eye on the BIOS updates and feedback and it makes me think I'm better off staying with 0702 even though it's an older version. I also have a 3990X and wasn't amused when I found out that I purchased what now appears to be an obsolete motherboard when ASUS announced the alpha variant weeks after I had purchased and installed the Zenith II Extreme in advance of the CPU's release. I was one of the lucky few to get my hands on the 3990X over a week early however, so not all bad I guess . I did ask ASUS on their Twitter about this problem and they never replied, which I guess goes to show how poor their customer service is. Usually good quality products but if you need support then you're likely to be out of luck.
  7. #7
    ROG Guru: White Belt Array
    Jan 2019
    77
    looks like temps on 902 and Alpha are quite higher with same bios settings.. could be power consumption.. Voltage has increased ?
  8. #8
    Jan 2012
    13
    45
    idk maybe a degree or 2 difference between the 2 bioses I wouldn't say quite higher for me at least. The one thing I am constantly amazed by is how much cooler the 3990x is over my 3970x. Same cooler and I noticed this with the 3990x on the base non alpha and thought oh its because the memory controller isn't working, but now with the memory set to the same 3600mhz as the 3970x. Doing the same Aida64 FPU stress I would constantly bump up against the 95C limit on the 3970x sure it was at 3.9ghz, but on the 3990x at 3.6ghz same test same everything else I stabilize at 80C. So not sure how double the cores and only a 300mhz loss in perf can result in a 15C temp difference. The only thing I can think is AMD is putting golden CCXs on the 3990x because they are charging so much. No clue, but its amazing and for that reason alone I think is worth the extra 2k AMD wants for the chip.
  9. #9
    ROG Member Array
    Jun 2016
    Quote Originally Posted by betaman10 View Post
    At a guess, it could be that the 3990X has the best binned cores compared to the other threadripper processors in the same generation. It's extremely power efficient under full load, each core only consumes a few watts each which for the performance of the 3990X in my view is simply amazing power efficiency. You may even potentially be able to squeeze more power effiency out of the CPU, if it's like the 3970X for example. For the 3970X they (computerbase article?) were able to reduce the PPT by around 30% I believe, with only around a 10% performance drop on that CPU.
