Results 1 to 3 of 3
    New ROGer Array
    Mar 2020
    1
    Sonic Radar II failure
    I am a deaf gamer and would like to use sonic radar to interpret directions of sound. To get sonic radar I have downloaded the realtek drivers via the ASUS website. This download folder includes sonic radar II. Sonic Radar II is installed on my pc. However it does not detect sound. It does show me the circle/radar. But if I run a test there is no pointer in the radar. I think the program does not detect sound on my pc. Is someone here who had the same problem and had fix this? If yes how can I fix this.
    Ps. Sonic Radar III is not supported on my device, which is also a problem.
    Thanks in advance,
    Boze Papa
    New ROGer Array TheMajekalBum PC Specs
    MotherboardTUF Gaming x570-PLUS(WiFi)
    ProcessorAMD Ryzen 9 3900X
    Memory (part number)64GB TridentZ Neo 3600mhz
    Graphics Card #1ROG Strix RTX 2080 TI OC
    MonitorROG PG27UQ 27" 4k 144Hz
    Storage #1WD Black SN750 1TB NVME
    Storage #24TB Seagate BarraCuda 2.5" HDD
    CPU CoolerROG Ryou 240mm w/oled
    CaseThermaltake View 71
    Power SupplyROG Thor 1200 watt
    Keyboard ROG Claymore (CherryMX Red)
    Mouse ROG Spatha & Chakram
    Headset ROG Centurion
    Mouse Pad ROG Balteus QI & Sheath
    Headset/Speakers Bose Soundlink Mini
    OS Win 10 pro
    Network RouterROG Rapture
    Accessory #1 ROG Spotlight
    Accessory #2 ROG Magnus
    Accessory #3 Rog Terminal
    Mar 2020
    51
    I bought a centurion headset and got it yesterday. The bundled software(ASUS ROG 7.1) included sonic radar pro and I made sure it was working. Just opened the software up and checked without the headset base station plugged in and it didn't show anything. It did show direction after plugging the base station in.
    Sucks to say but I think you may need compatible 7.1 channel surround sound hardware plugged in before it will work.
    ROG Guru: White Belt Array DSD27 PC Specs
    DSD27 PC Specs
    MotherboardMaximus VI Hero
    Processori5 4670K @ 4.5 GHz 1.28v
    Memory (part number)F3-14900CL9D-8GBXL
    Graphics Card #1Asus Expedition GTX 1070 OC 8GB
    MonitorAOC Q3279VWF
    Storage #1Kingston SSDnow 300v 120G
    Storage #2Western Digital Blue 1TB
    CPU CoolerThermalright True Spirit 140 BW
    CaseZalman Z11 Plus
    Power SupplyXFX Pro 750W Core Edition
    Keyboard Cooler Master CMSorm Devastator
    Mouse Razer Abyssus
    Headset ROG Orion
    Mouse Pad SteelSeries qck+
    OS Windows 10 Pro 64bit
    DSD27's Avatar
    Jul 2013
    120
    The program works with stereo, it detects the sound, but you need to select 7.1 in realtek for it to display 360 degrees. If you're not having any response on the program, then it's really not working, there may be something wrong.. check if you have "disable all enhancements" checked in the speakers settings, if so, unckeck it.
    Mine still works on my VI Hero.
    i5 4670K @ 4.5 GHz, Maximus VI Hero, Thermalright True Spirit 140 BW, G.Skill RipjawsX 2x4GB 1866mhz CL9, ASUS Expedition GTX 1070 OC 8GB, XFX Pro 750W Core Edition, Kingston SSDnow 300v 120GB, Western Digital Blue 1TB, Zalman Z11 Plus, ROG Orion, AOC Q3279VWF
Tags for this Thread
