Sli Rtx2080 ti with titan Rtx
elkhog
Anybody Sli Rtx Titan with a Rtx2080 ti.
6 REPLIES 6
Braegnok
Level 14
Most likely would work, it would down clock the Titan card however so not a vary cost effective SLI configuration.
Would be better running single card with the Titan.
Sydneyblue
Why would you want to do this ?
I agree. Why???
Nate152
It won't work, to SLI you need the same model of gpu with the same core count and same amount of memory.
Nate152
In some games a 2080 Ti struggles to maintain a solid 60FPS at 4k resolution. If the game supports SLI, two of them will ensure you never dip below 60FPS. Or, if you have a 4k 144Hz monitor such as Braegnok has, then two 2080 Ti's or Titan RTX's is a real treat.
Arne_Saknussemm
Level 40
Nate is, of course, correct...you need same memory amount etc to SLI properly...you can find hacked drivers for same gen stuff but it's always a compromise and might not work well...
