Rog spatha wireless problem
nickDroy
I bought the Rog spatha after hours trying to fix the aura because it need an old armory , now when i have it on wireless mode the mouse when i move it slowly it moves left instead of being accurate it happened when i restart my pc and before it solved by itself now it doesnt !
Can anyone assist me ???? i cant find any info on how to fix it
18 REPLIES 18
Murinko86
same happend to me after i updated the frimwave and driver not it's completly useless in wireless mode. I 'm thinking about to change to razer and absolutly forgot ASUS....
the problem was the pairing ! now after 4 days that i thought i fixed the pairing ! when i put to charge under 90% on the dock it changes the color to pulsing green!
it's crazy and messes up all my aura ! are we serious its on the most expensive mice in the market and the dont care to give us a good crate to easily work !
ASUS WAKE UP !!!!!!
I WANTED TO DO A FULL ASUS ROG PC BUILD BUT AFTER ALL THESE PROBLEMS NOOOOO WAY !!!!!!
So when i download the firmware 1.80 from the site and try to open it nothing happens.......... any solutions ????
Check replies in your other threads please.
Have to mention though that mine randomly stops the cursor moving (mouse on 1.80, receiver on 1.40). No massive deal since it happens only every once in a while. Have the impression it occurs less since I did the update, but no occurrence would be even better.
You using it wired, wireless, or hybrid (receiver plugged in but also wired for charging)?
I found my Spatha did weird stuff if plugged in hybrid in the computer. I know thats not a normal configuration but I figured Id throw this out there.
Hey Majekal
I use it exclusively wireless and charge it on the receiver. When it's on charge, I either use a razer mamba 2012 or a steam controller *both in wireless* as a mouse.
Also run a cheap & loud & laggy but usable Rii keyboard with a wireless dongle. That one has no specialist software with it.
I tried several things so far (not sure which of them since the firmware update, so will probably have to go through them again):
  • Unplug all the other dongles (mamba, steam, keyboard)
  • Close Razer synapse, close Armoury, and close both
  • Uninstall razer synapse
I'll probably look into uninstalling Armoury and closing Steam too.
At the moment I am fine with it since I don't play anything competitive/multiplayer but would be cool to figure it out.
HappyBerryTeddy wrote:
Hey Majekal
Switched to another keyboard (Drevo BladeMaster 87) a few days ago and the mouse getting stuck issue seems to be occurring way less if at all. Maybe the Rii dongle was causing some interference.
sunny74688
any one found any solution to ROG Spatha
Hi Sunny & welcome
What does your issue look like? Similar to nickDroy's, mine or something else completely?
