Results 1 to 3 of 3
    New ROGer Array
    Mar 2020
    2
    Angry I have a problem with the XI hero wifi and the Ram
    I tested a lot of rams and do no work.
    Always the system puts memory OK on the start and the bios puts me the vccio to crazy numbers
    I have a set of 3600 cl 16 and do not work good at 3600 only at 3200
    I have another set to 4133 cl 19 (with this not even start ever)
    And i have another of 3400 cl 16 and its the same like 3600 cl 16 only work at 3200mhz
    And i have another of 3600 cl 19 and 3600 cl 18 and the same, i dont know what more i can test or do always MEMORY OK and a crazy values on Vccio and system agent voltage
    Im so lost at this point
    PD: i use the las bios version and yes i turn back to an older bios version and it dids the same. (i did a clear cmos too )
    Id anyone can help i would apreciate it so much THX.
    ROG Enthusiast Array howxcore PC Specs
    howxcore PC Specs
    MotherboardMaxims XI Hero- Wifi
    ProcessorCore I9 9900k 5.0 ghz
    Memory (part number)G.skill tridentz rgb 3600mhz 32gb
    Graphics Card #1msi rtx 2080ti trio x Gaming
    Sound CardSound Blaster X AE-5
    MonitorViewsonic XG270QG, BENQ PD3200U
    Storage #1970 evo m.2 1tb
    Storage #2Sandisk Ultra 3D SSD 2TB
    CPU Coolernzxt kraken x62
    Casenzxt 700i
    Power Supplyseasonic titanium 1000w
    Keyboard logitech g915 TKL
    Mouse logitech g502
    Headset Logitech G935 wireless
    Mouse Pad ICEMAT
    Headset/Speakers logitech z5500
    OS windows 10 pro 2004
    Nov 2018
    49
    Quote Originally Posted by rukssian19 View Post
    first what is the exact memory module your using (vendor) and model #.. and have you used any XMP profiles? (XMP, XMPII)
    New ROGer Array
    Mar 2020
    2
    Quote Originally Posted by howxcore View Post
    yes always i used xmpII but i tested with xmp1 and the pc do the same thing.
    i used this 4:
    #1: F4-3600C19D-32GSXWB (never worked)
    #2: PVS416G340C6K (this worked from july to december/january --- i was using 4 modules for 32gb)
    #3: F4-3600C16D-32GTZNC (now working, but when i have the pc a few hours OFF the VCCIO and the VCSA changes randomly)
    #4: PVR416G413C9K (never start with 4 modules (it say CC error), only start with 3 but do not work with xmp)
Tags for this Thread
