Results 1 to 10 of 10
    ROG Member Array ATLANTICA_NFS's Avatar
    Jun 2017
    22
    GU502GV - Fan issues
    Hi folks.
    yet another post regarding my recently purchased GU502GV...
    Two days ago, one of the fans started to sound "weird" (hard to describe) - as if something would obstruct the fan-blades from spinning.
    As soon as the fan ramps-up to higher speeds, the scratching-sound goes away but would return as soon as the fan slows down / returns to "idle"-mode.
    The Notebook has never been moved / transported, always been sitting on my desk - quite unsettling first impressions so far TBH (especially regarding the rather high retail-price).
    Just wondering if someone else has had similar experiences with this particular model?
    I've contacted the re-seller & they're willing to exchange the Notebook so here's hoping the new GU502GV won't break down after 7 days of use as well...
    Best regards
    ROG Member Array
    May 2020
    Did you have better luck with the exchange?
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / ROG Ryujin 360
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    31
    439
    Here is what I would do: Get a paper clip and unbend it. Then place it in the vent to prevent the fan from spinning. Then get a leaf blower and blow inside to get all dust and anything else out. If you don't have a leaf blower (which is the best to use here), then use a vacuum cleaner, but preferably one with a good, strong motor--and vacuum it out as best you can. Then check and see if you get the sound. If you still get the sound then I'd google the model number for videos that show you how to open your gizmo up. You can usually find ones for changing memory or putting in more ram. Then with it open I'd blow/vacuum it out (with the fans stopped from spinning) and look around for anything loose that might be hitting your fan(s). I'd also check to make sure the fan(s) is/are not somehow loose.
    One caveat: I'd be careful though about doing anything that might void your warranty. So before opening it up I'd check the documentation.
    Jun 2017
    22
    @super Gnome
    Thanks for the input / tips! Received an exchange-device but had to send this one back as well (thermal-issues / GPU-"safe-mode-throttling" after one week of use...)
    @redrooster808
    Well, the fans did work flawlessly... then the GPU started to act-up ("safe-mode-throttling") after only one week of use.
    Sent it in for RMA / repair and sold it right away once it got returned...
    I really liked the GL502VMK but the GU502GV was one hell of trouble...
    Best regards & thanks again for your messages
    Moderator Array
    Feb 2019
    15
    916
    Hello ATLANTICA_NFS,
    I'm really sorry about this.
    If you still have the record of the SN for both devices,
    please kindly provide them through PM.
    Thank you so much.
    Jun 2017
    22
    Hi Blake@ASUS,
    thanks for your post - no worries, these things can happen. I guess I had some bad luck with the "in-stock"-batch.
    I'll check whether I can recover both serial-numbers.
    Best regards
  7. #7
    New ROGer Array
    Jun 2020
    2
    Same thing here
    Same thing here. Proud owner of a Zephyrus M up until about a month and a half ago, when the charger went. Sent it in under warranty (cost me $60 in postage, grr) and got it back 3 weeks later with a new charger. 4 days later, the left-side fan started to rattle. The computer is now out of warranty, so I'm probably facing a hefty BestBuy repair bill to fix that fan, since Asus don't sell replacement parts. I did actually take it apart and clean it out, and I was able to confirm that it's the actual fan rattling and not just a buildup of dust. I guess a bearing broke or something. As much as I love this computer, I am going to sell it as soon as I get this fan repaired, because 2 major reliability issues in my 6 months of ownership is not a good omen.
  8. #8
    Moderator Array
    Feb 2019
    15
    916
    Hello novecho_delta,
    May I have a record of the sound?
    Thank you so much.
  9. #9
    New ROGer Array
    Jun 2020
    2
    Hi Blake@ROG,
    I'm so sorry I left you hanging for 14 months. I don't know why this would still be useful, but I can provide a recording if you would like - let me know.
    I had the left side fan replaced at BestBuy last summer, only to have THE SAME issue happen with THE SAME FAN. In addition, I'm on my third charger, and it's on it's way out - failing in the same way as the last two I bought. I also woke up two days ago to my computer's trackpad no longer working. If anyone plans on buying this computer second hand or anything, DON'T. This is ridiculous, especially given that my computer isn't even 2 years old.
  10. #10
    New ROGer Array
    Oct 2021
    1
    GU502LW Issue
    Quote Originally Posted by Blake@ROG View Post
    Thank you so much.
    Hello Blake@ROG, I am having the same issue with my GU502LW - anything you can do?
