Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 40
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus M13EG Bios 1007
    Processori9 11900K @ 5.2 1.50 VCore
    Memory (part number)GSkill F4-3600C16D-32GTRS
    Graphics Card #1Asus 3090 Strix OC/Optimus Block
    Sound CardCreative SB X4
    MonitorAsus ROG XG349C
    Storage #1Samsung 980 Pro
    CPU CoolerQuantum Kinetic TBE 300 D5 with Quantum VTX 160
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus ROG Claymore 2
    Mouse Asus ROG Gladius III
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    New driver and FW for aquantia 107
    On the Marvell site, looks like new FW and driver 109 and ....21 respectively. **https://www.marvell.com/support/downloads.html
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Installer for the driver worked fine, but the FW did not.
    ROG Guru: Yellow Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO 1TB SSD + 64GB RAM
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #14 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #24 x Samsung SSD NVMe 970 PRO 1TB Raid0
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseROG Strix Helios
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Scope Deluxe & ROG Strix Scope TKL Deluxe
    Mouse 2 x ROG Chakram
    Headset ROG Throne Qi
    Mouse Pad ROG Balteus Qi RGB & ROG Sheath
    Headset/Speakers 1 x ROG Strix Go 2.4 & ROG Strix Wireless
    OS Win10_x64
    Network RouterFRITZ!Box 6660 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 ROG STRIX ARION & Asustor AS6404T
    Accessory #3 2 x HYPER M.2 X16 GEN 4 CARD
    Dimitrios1971's Avatar
    Apr 2015
    74
    141
    Quote Originally Posted by Hopper64 View Post
    It is normal for you that the FW does not work on your motherboard.
    Supported devices
    Motherboards with 10GbE / 5GbE
    ASRock Fatal1ty X299 Professional Gaming i9 XE
    ASRock Fatal1ty X399 Professional Gaming
    ASRock Fatal1ty X370 Professional Gaming
    ASRock Fatal1ty Z370 Professional Gaming i7
    ASRock X470 Taichi Ultimate
    ASRock Z390 Taichi Ultimate
    ASRock Fatal1ty Z270 Professional Gaming i7
    ASRock Z270 SuperCarrier
    NIC, TB3 dongles, and TB3 docking stations
    Aquantia AQtion 10G Pro NIC
    Aquantia AQtion 10G Gaming NIC
    Aquantia AQtion 5G Pro NIC
    Aquantia AQtion SFP + NIC
    Gigabyte GC-AQC107
    Promise SANLink3 N1
    QNAP QXG-10G1T
    QNA-T310G1S
    QNA-T310G1T
    Sonnet Solo10G SFP + Thunderbolt 3
    Sonnet Technologies Solo 10G Thunderbolt 3
    Example updating a NIC with 3.1.58 firmware to 3.1.109
    And drivers
    Change log:
    v2.1.021.0
    Date 05.03.2020
    - Fixed checksums which were reported to OS for packets with non-zero padding
    Supported OSes: Windows 7, 8, 8.1, 10, Server 2012/2016/2019
    Supported devices: AQC100, AQC107 / 108, AQC111 / 112
    AQC100S, AQC107S
    OLD
    NEW
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Yes. I misread that. Thought I saw Asus X299... Was in a hurry when reviewing that. Thanks.
    Nov 2011
    26
    172
    You can still install the firmware if you so like.
    Use the flasher from this thread https://rog.asus.com/forum/showthrea...irmware-Update
    move the 3 .clx files from the 109 firmware to the above mentioned flasher and rename them to the names expected in the xml file or edit the xml file with the new names
    ROG Enthusiast Array leghmoh PC Specs
    leghmoh PC Specs
    MotherboardRampage VI Extreme Encore
    ProcessorI9 10940X
    Memory (part number)Corsair Dominator Platinum 3600 Cl-18
    Graphics Card #1GTX 2080 Ti
    Graphics Card #2GTX 2080 Ti
    Sound CardDenon AVR-X3500
    MonitorDell U3219Q
    Storage #1Samsung 970 pro plus
    Storage #2Samsung 850 evo
    CPU CoolerWatercooled
    CaseCorsair Obsidian 900D
    Power SupplyCorsair Platinum AX1500i
    Keyboard Logitech G910
    Mouse Logitech G502
    Mouse Pad Logitech G440
    Headset/Speakers 5.1 Klipsch RP-400M - 400C - R-110SW
    OS Win 10 _ 64Bit
    Network RouterNetgear XR700
    leghmoh's Avatar
    Jun 2012
    20
    60
    Quote Originally Posted by broncogr View Post
    Thank you very much broncogr, your tips worked fine again for me.
  7. #7
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Thanks, but is it necessary since Asus boards aren’t mentioned? Does it fix the issue outlined for our Asus boards?
  8. #8
    Hopper64 PC Specs
    OS Windows 11 64
    Hopper64's Avatar
    Nov 2012
    57
    2,360
    Another thing I was thinking today was if the FW is needed for Asrock x299 wouldn’t be applicable to Asus x299 boards?*
  9. #9
    Nov 2011
    26
    172
    No idea.
    Mine flashed successfully though
  10. #10
    ROG Guru: Orange Belt Array vmanuelgm's Avatar
    Sep 2013
    50
    342
    Thanks for the info, mates!!!
    Aquantia 10G Firmware Update 3.1.109 for Asus Boards.
    https://mega.nz/file/Q7pz1bKA#SaxXQW...eCNVUnoqaf-oRg
    Just execute as admin atlflashupdate.exe, press y, and then select your adapter (1) and enter, wait, finished.
    Omega, 10980xe, G.Skill 3600, 2080Ti, SM951 256, 970 PRO, 860 EVO
    Intel 750, WD SN750 Black, 840 Pro, 2xSkyhawk 4TB, 7200.14, 207EBK
    EVGA T2 1600, Silverstone TJ11, Custom LC. @Acer Predator x34
