Terminal wont shut down with pc
CHHBadkarma
Greetings,
Have the terminal set up externally running on ac power and connected to the pc via usb. When I power off the pc the terminal stays on and reverts back to rainbow. is this normal? Ideally would like to have it power off with the pc
TheEternaL
CHHBadkarma wrote:
Greetings,
Yes its normal.
Turn off the computer.
At the Terminal, press the button until all the LEDs go out.
After that, management is only through the application.
TheEternaL wrote:
Yes its normal.
excellent. Thanks for the quick reply
