Results 1 to 3 of 3
    ROG Member Array
    Jun 2019
    11
    Rog strix hero 2 g504gm battery problem
    Hi there
    I bought back in august a rog strix hero 2 gl504gm and I have been experiencing battery problems lately. Every time when I boot up my laptop on battery (even when fully charged) he boots up and then all of the sudden I get the message: "battery low 0% locking" and he shuts down. Then when I boot it up again he indeed has 0% left. The laptop is less then a year old so the battery cannot or should not be broken yet right? When I boot up my laptop with the charging cable in, it boots up and when I disconnect the cable I can use the laptop on battery normally without any problems. How is this possible? Also I made a battery report that shows that my max battery capacity is going up and down randomly. Can anybody explain this and solve this issue for me. I will put the battery report in the attachment.
    Ok apparently I cannot upload the file so here is a link to my google drive with the file: https://drive.google.com/file/d/18QW...ew?usp=sharing
    Kind regards
    Seppe
    ROG Member Array
    Jan 2019
    23
    Hi Seppevs,
    Try checking this topic, even if the issue is not solved. We will try to get as many messages a possible here https://rog.asus.com/forum/showthrea...l504gm+battery
    ROG Member Array
    Jun 2019
    11
    Quote Originally Posted by dan_himura View Post
    Hi Seppevs,
    Thanks a lot!
Tags for this Thread
