Results 1 to 3 of 3
    New ROGer Array
    Aug 2019
    2
    Unhappy GPU lights breathing red on startup regardless of Aura Sync Customization
    On startup, my GPU (ROG Strix GTX 1660 Ti) lights up in breathing red. That's regardless of the Aura Sync customization I have set. For example, I could have the Aura Sync RGB in general disabled, yet the GPU would still light up in red and keep breathing red until I open up Aura Sync, which sets it back to the actual customization (For example, if the whole RGB is off, it turns off. If it's customized to a certain color/mode, it syncs to it.) or until I turn the PC off. In short, I want to have the GPU's RGB synced with the rest of the components without having to launch Aura Sync every time I turn on the PC. Mobo is ROG Strix B450-E (uncommon edition, it's basically the B450-F but a bit beter)
    New ROGer Array TobesEtc PC Specs
    TobesEtc PC Specs
    MotherboardAsus Prime Z390-A
    ProcessorIntel i9-9900K
    Memory (part number)Corsair CMK32GX4M2A2666C16 Vengeance LPX 32 GB (2 x 16 GB) DDR4 2666 MHz C16 XMP 2.0
    Graphics Card #1ROG Strix RTX2070 Super
    MonitorAOC 2777PQU
    Storage #1Samsung 970 Evo 1TB
    Storage #2Samsung 860 Pro
    CPU CoolerROG Ryuo 240
    CaseCorsair 100R
    Power SupplyCorsair RM750x
    Keyboard MS Modern w Fingerprint
    Mouse MS Surface
    Headset Audio-Technica ATH-W1000X
    Mouse Pad er.... Ikea desk?
    OS Windows 10
    Network RouterSky Q
    Accessory #1 ASUS PCE-AC88 Wireless PCI-E Network Interface Card
    Accessory #2 ASUS USB-BT400 3Mbps USB Bluetooth v4.0
    Accessory #3 DEEPCOOL RF120 5IN1, 5x120mm RGB PWM Fans with Fan Hubs
    Jan 2020
    15
    Have you got AURA RGB Control for Graphics Card installed as a separate layer of complexity? Why it's separate, no one can explain. I have that & Armoury Crate running - seems to be reliable-ish. In terms of "Reliable for Aura Sync" (ie, not very).
    https://www.asus.com/supportonly/AUR...pDesk_Download
    > Drivers & Utilities > Choose OS > AURA RGB Lighting Control for Graphic card & XG-STATION ver0.0.6.7
    ROG Guru: White Belt Array
    Jan 2018
    5
    115
    They made Aura Halo a separate program too. Absolutely stupid.
Tags for this Thread
