Results 1 to 4 of 4
    ROG Member Array
    Dec 2014
    16
    22
    Zenith II Extreme, AMD 3960x, no "what u hear" or "stereo mix" recording option
    Hi, In my previous PC build I was able to select "Stereo Mix" or "What U Hear" as an Input device in order to record what was coming out of the PC's speakers. In this new system that option isn't available. I still cannot see it via show hidden or disabled devices options. Can anyone help, thanks!
    ROG Member Array
    Dec 2014
    16
    22
    No help?
    To ask in another way...has the audio system in this motherboard done away with the ability to select a "what u hear" / "stereo mix" option?
    ROG Member Array
    Dec 2014
    16
    22
    Close to 3 months later and still no response.
    Pretty stunning support we have here in the forum - thanks Asus. I'm leaning very strongly towards permanently halting any future purchases of Asus products.
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1System : SSD Samsung 960 EVO 256GB
    Storage #2Games : SSD Corsair MP510 240GB | Data : SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 20H2/VB/19042.x
    MoKiChU's Avatar
    Aug 2013
    229
    473
    Try with Realtek USB Audio Drivers (UAD - ASUS ROG/PRIME MB) from my UAD drivers thread for AMD TRX40. Follow scrupulously your INSTALL process with cleanup step, for the next drivers packages that I would release, you will can directly follow the UPDATE process.
    Note (in order to choose correctly the install/update process to use) : You have a ASUS ROG SS3|DTS Sound Unbound motherboard.
    Regarding your recording needs, Sonic Studio Virtual Mixer (in Sonic Studio III) will cover this need :
    From official ROG SS3-DTS Sound Unbound motherboards overviews :
    SONIC STUDIO VIRTUAL MIXER
    A virtual audio device that lets streamers combine sound output and output from different apps.
    This allows you to mix your voice and video game audio within streaming software. A variety of adjustment and monitoring tools provide a high level of digital control.
