Results 1 to 3 of 3
    New ROGer Array xobotyi PC Specs
    xobotyi PC Specs
    MotherboardAsus Crosshair VIII Impact
    ProcessorAMD Ryzen 3950X
    Memory (part number)G.Skill DDR4 3200 2x16GB
    Graphics Card #1MSI RTX 2080Ti Ventus GP OC
    Storage #1WD Black nvme ssh 1tb
    CaseNZXT H710
    Power SupplybeQuiet Straight Power 11 750W
    Keyboard Logi MX Craft
    Mouse Logi MX Master 2s
    Headset AKG K702
    OS Win 10
    Network RouterRT-AC66U
    Mar 2020
    2
    Crosshair VIII Impact Backplate LED issue
    Have an issue with backplate LED's color.
    As you can see in attachement (sry for reflections been lazy to unmount the glass), EK D-RGB waterblock and SODIMM module has correct color (circled by red marker) while mobo's backplate LED's somewhy colored green (circled with creen marker).
    Tried to apply the color in different programs (aura, armory, icue) but none hepled, yellow related colors are always green.
    Armory updated some drivers, and if i remember right there was something related to led firmware, but now im using Aura Sync, besause Armory is piece of **** and resets to default rainbow after every shutdown/hybernation.
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorMSI Oculux-NXG251R
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    Headset/Speakers Astro A40TR
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    47
    555
    in aura is the d ram and add strip chained together as in white icon under them. If no add strip in aura go to settings in aura and add strip for gpuClick image for larger version.
Name:	aura setting.png
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    xobotyi PC Specs
    CaseNZXT H710
    Headset AKG K702
    OS Win 10
    Mar 2020
    2
    Quote Originally Posted by drop4205 View Post
    Its not a strip it is integrated LED backlight, has no separate configuration and only a part of 'Motherboard'.
    It is configurable only via addressable section but thats not my issue my issue that all yellow-related colors are green in fact in motherboard backplate LEDs.
    My config is set to a single color for all, every other strip including SODIMM slot has correct color, but not backplate (its not actually backplate leds, they're soldered on the back of MB).
Tags for this Thread
