Results 1 to 5 of 5
    New ROGer Array
    Jul 2018
    3
    Upgrading G20AJ GPU need help!
    Hello everyone soo i have ASUS ROG G20AJ the one that has i7 4790 and gtx 760 and i want to upgrade to RTX 2060 but i realise my modal it came only with 1x6 pin connector and no 1x8 pin connector. Is this specific modal didnt came with one? i cant have any GTX 1060 turbo anymore because it is hard to find nowdays and amazon is selling expensive which requires only 1x6 pin. Unless the 8 pin is already being used inside my the rig.
    ROG Guru: Orange Belt Array raju2529 PC Specs
    raju2529 PC Specs
    Laptop (Model)R542UQ-DM153 ( X542UQ.309 )
    MotherboardAsus Builtin Motherboard X542UQ
    ProcessorIntel core i5 7200u @2.5Ghz
    Memory (part number)Adata 2400 Mhz 16GB
    Graphics Card #1intel Hd 620 graphics 1GB DDR3 driver v 7988
    Graphics Card #2Nvidia GeForce 940MX 2GB GDDR5 driverv 445.78
    Graphics Card #3nil
    Graphics Card #4nil
    Sound CardRealtek HD Audio controller with codec 294
    MonitorBuiltin Lcd monitor
    Storage #1Samsung 850 Evo 250GB SSD M.2. 2280
    Storage #2Seagate 2TB 2.5inch. Toshiba 1TB 2.5 inch
    CPU CoolerBuilt-in
    Casefrom factory
    Power Supply65W
    Keyboard Built in keyboard
    Mouse Built in mouse
    Headset Purchased Philips HeadSet
    Mouse Pad nil
    Headset/Speakers Realtek Builtin Speakers
    OS Windows 10 Enterprise 64bit 1909 build no 18363.753
    Network RouterBsnl Wi-Fi modem with router
    Accessory #1 Dell Wired Mouse
    Accessory #2 Laptop Cooling table with fan
    Accessory #3 Secureye Usb finger print scanner added sepeartely
    raju2529's Avatar
    Feb 2018
    9
    304
    Dont upgrade keep with that in same motherboard.
    If you want upgrade GPU purposely, then you must change MB , processor,. RAM module, Cpu coolers, PSU , cabinet
    New ROGer Array
    Jul 2018
    3
    Ive seen others upgrade their rig with this modal why would i want to change MB, RAM etc2. Others has succesfully upgrade their GPU even with rtx 2060/80 without changing nearly everything and i might be going for gtx 1060. Tho my question was still remains is this particular modal didnt come with a 8 pin connector?
    ROG Guru: Yellow Belt Array Welsh Whoopee's Avatar
    Jan 2016
    18
    241
    Quote Originally Posted by HighDarkTemplar View Post
    hello, the model that you have will have the GTX 760, it doesn't need power to run that card and takes the power off the pce-i lane, you can get the gtx 1060 turbo but mainly off sites ebay etc.... its easy to upgrade to a TRX 2060, I can you links to the power cables you need, you will also need a 180w power brick and then the RTX 2060, where are you based in the world? its much easier for me to get you the links, I can only get the items off ebay. btw if you came over to my channel and asked on a video then you could have had a answer soon, my videos are on the top of this section forum.
    Whoopee
    YOUTUBE CHANNEL @ http://bit.ly/2LNo1dI
    ASUS ROG G20 PLAYLIST @ http://bit.ly/2R9njXC
    New ROGer Array
    Jul 2018
    3
    Ahh yes i know you i watched your video on the guide which is very helpful i am commenting on your latest video from now on. its on the gaming channel
