Results 1 to 8 of 8
    ROG Member Array dwightturner36's Avatar
    Mar 2016
    8
    Lottery lost: I9 9900k + Maximus XI Hero + Corsair H115i pro AIO
    Final stable with prime 95 non AVX Small Ftt and realbecnh for 8 hrs +:
    MAX temps during stress test 87c then settled to 83C
    XMP2
    Sync all cores 49
    AVX 0
    cache 43
    vcore 1.34
    LLC 5
    Power limits removed
    this is the best this thing will do so after a long time messin with it Im done! gonna leave it as is.
    ROG Guru: Green Belt Array drop4205 PC Specs
    drop4205 PC Specs
    Laptop (Model)What are laptops
    MotherboardMaximus XI Formula
    ProcessorI9-9900K
    Memory (part number)Gskill Trident Z F4-3200C14-32GYZR
    Graphics Card #1Nvidia Reference RTX2080TI
    Graphics Card #2ha I wish
    Graphics Card #3ha I wish
    Graphics Card #4ha I wish
    Sound Cardha I wish
    MonitorMSI Oculux-NXG251R
    Storage #1Samsung970 EVO Plus 1T
    CPU CoolerHeatkiller
    CasePhantex Evolove X
    Power SupplySessonic Prime Titanium 850
    Keyboard ROG Strix Flare
    Mouse ROG Gladius II
    Headset Astro A40
    Mouse Pad Corsair
    Headset/Speakers Astro A40TR
    OS Windows 10 Home 64 Bit
    Accessory #1 Ek GPU Block
    Accessory #2 EK SE 360 Rad, EK PE 360 Rad
    Accessory #3 EK D5 Vario 140 Pump/Res
    drop4205's Avatar
    Mar 2013
    47
    554
    lol nice. Im messing around with mine now.
    XMP1
    sync all 5.1
    AVX1
    cache43
    vcore 1.27
    LLC6
    temps 75 to 80
    Ran realbench for quite a few hrs, Cinebench numerous times. Kinda fun to mess with. Lots of reading and learning and trying.
    Maximus XI Formula, I9-9900k, Phantex Evolove X, Seasonic Titanium 850W, Custom loop PE360+SE360 Rad, G.Skill Trident Z F4-3200C14 32g, Nvidia Reference RTX 2080 TI, Samsung 970 EVO Plus 1Tb, ROG Strix Flare keyboard, ROG Gladius II
    New ROGer Array nikkotuason PC Specs
    MotherboardROG Maximus XI Apex Z390
    Processori9-9900K @ 5.2GHz 1.39v (Direct-Die)
    Memory (part number)Trident Z Royal @ 4200MHz CL18
    Graphics Card #1ASUS ROG RTX 2080 Ti O11G
    MonitorSamsung CHG70 32" QLED, 1ms 144Hz
    Storage #1970 Evo Plus M.2 2280 1TB
    Storage #2Seagate IronWolf Pro 16TB
    CPU CoolerSwiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish
    CaseLian Li PC-011 Dynamic (White)
    Power SupplyMasterWatt Maker 1200
    Keyboard Logitech G815 Tactile
    Mouse Logitech G Pro Wireless
    Headset Audeze LCD-4
    Mouse Pad Logitech G840
    Headset/Speakers Kanto YU4 + Kanto SUB8 8"
    OS Windows 10 64
    nikkotuason's Avatar
    Oct 2019
    7
    Sync all cores 5.2
    AVX 0
    cache 47
    vcore 1.39
    LLC 6
    Temps 80-90C
    Mar 2016
    8
    yea my chip will not go beyond 4.9 and be rock solid
    even when i tried to go 5GHZ with avx of -1 and more vcore it **** itself after 20 mins
    drop4205 PC Specs
    ProcessorI9-9900K
    Sound Cardha I wish
    Headset Astro A40
    Mouse Pad Corsair
    drop4205's Avatar
    Mar 2013
    47
    554
    yeah its a lot of time to adjust stuff and test then fail and adjust some more and gain. I normally just run xmp and no other oc when playin on pc but have the oc save to go back and tweak some more.
    ROG Guru: Orange Belt Array
    Feb 2019
    67
    260
    First things first, uninstall prime95 and forget you every heard of it. Prime95=ho to turn PC into space heater.
    Download something like realbench and select the stress test. That more indiciative or real workloads or blender then get the classroom or Viranda render and run it in animation mode where it will render it over and over until you stop it.
    Cant win them all, whats your heat doing? 87 is a bit on the high side, get that down to 80C or less on hottest core and bet you can squeeze 5Ghz out. Crap I can get 5.1 GHz out of a 9940 but thats on a custom loop, not an AIO. But If I were to choose and AIO the H115I is a good choice. Keep one around for testing new boards and CPU before I stick them in the case.
  7. #7
    ROG Guru: Yellow Belt Array Carlyle2020 PC Specs
    Laptop (Model)amd4000 for sure next time
    MotherboardAsus Maximus XI APEX
    Processorgaming9900ks/@5.1 avx -1 / adaptive auto vcore/LLC5/AC+dc 0.01/TVB on/all power savings on
    Memory (part number)Corsair LPX 4000 CL19@16.17.28/300/2T/ 1.42 volt
    Graphics Card #1Gainward RTX 2080Triple/tempsense on Displayport needed
    Sound CardXonar STXII mods:3xLME 49720NA
    MonitorLG 38GL950G / -HDR / +madVR
    Storage #12TB 970evo plus nvme
    Storage #21TB 960evo nvme +2x 1tb evo 860 hw-sata-raid
    CPU CoolerNoctua NH-D15 /pull+spacers/so not 100%
    CaseSilverstone FT2 dampened up the wazoo
    Power SupplySeasonic TX-850
    Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :)
    Mouse MX Master 3
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers A250 / cause LG was stingy
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off
    Accessory #3 4 bay fantec /10tb red/+scrap
    Mar 2018
    17
    142
    Double post. Sorry.
  8. #8
    Mouse MX Master 3
    OS Win 10 64bit
    Mar 2018
    17
    142
    9900ks tweaked for gaming and not rendering:
    multi: x51
    vcore: instead of 1.29 vcore with LLC 6 i run 1.32 vore with LLC 5 (5 degree cooler)
    avx - 1
    cache: x49
    Cooler: NH-D15 tweaked for pull config without buzzing noise (roughly around -3 to -7% cooling capacity)
    Limiting factor: 185 watt via Bios IF i render or cut vids.
    My Rig is not mission critical.
    So i dumped prime and OCCT(small data set) as well.
    The same RAM tweaks as with my 8086k yield lesser results by 0,5-1,3% due to...specter mitigations?
    Since it can only be about single core performance nowadays: 524 pts in R20
