D: Hard Drive Not Being Recognized
Derpajerb
Hey all you cool Cats and Kittens.
I've been troubleshooting this for a Month. I'm going to provide lots of pics because my technical jargon is not the greatest and i haven't had to TS like this since 2001
My D drive storage was disappearing from my pc intermittently for 2 months before this, I'd reboot and it would be back.
One day got my pc just said it had encountered an error and had to restart, that was the last time i was able to see my 😧 drive
Specs:
Win8.1
ASUS Desktop PC CG8480 Series
Intel Core I7-3770k CPU @ 3.50hz
Ram 16gb
64-bit
The Harddrive is a 3tb seagate
troubleshooting steps i've completed :
Swapped Sata Cables
Swapped Power cables
swapped hotplug positions
Drive does not show in disk management
Drive does not show in Device Management
Drive DOES work and can accessed if connect via USB with USB Adapter
i've unplugged all hard drives except the D:drive and it does not show in BIOS
uninstalled disk drivers in device management.
Below are some pictures of my bios settings and other settings. maybe there is something i'm missing.
84628
84629
84630
84631
84632
As you can see from this Pic the other drive is an SD card drive. not my D
84633
84634
I hope i've painted a picture on whats going on here.
sorry for the noob post. thanks for any help and your patience
-Jerb
9 REPLIES 9
Derpajerb
bump
raju2529
In your screenshot I confirmed you have only two harddisks.
One ssd and one hdd.
You dont have to other harddisks.
Only GPT formatted based hard-disks are available in bios
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
Yes 2 hard disk, my operating system is on a 100gb ssd. my second HDD is 3 Tb.
BUT in the 6th screenshot the second hard-disk showing my BIOS is not my hdd, that is a removable sd-card slot. i don't know why it is showing up there instead of my hhd
raju2529
disable Raid option , select ACHI mode , is your SSD contains EFI partition , Is 3TB harddisk is formmated as NTFS in GPT style ? ( dont format now )
When selecting ACHI mode, my OS will not start. I will get a blue screen saying there has been a problem and Windows must restart.
Yes SSD contains EFI partition.
I assume my 3tb is formatted as NTFS as I have not formatted or changed the format since my original startup.
i've now fixed the problem of not being able to load windows after switching to ACHI but the HDD problem presist
bump
bump
Your HHD may be dying, dropped or thrown during shipment to place of purchase. I have done all the troubleshooting steps that you have done, but with a WD Green HDD. When I looked at the date on the HHD, it was 24 Oct 2013 (when purchased). Therefore, I went to the WD warranty web site and input the HDD serial number:
84852
Note the description says it is a WD Blue HDD, but the label on the HDD is:
84853
Anyway, I brought a new HHD and transferred all the data to it, no problems since HDD replacement. Nevertheless, the old HDD (24 Oct 2013) still does the same thing as your HHD is doing now.
