Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / NZXT Kraken X62
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    295
    Rampage VI Extreme Omega Crash/Sudden Restart Problems
    In a nutshell:
    1. PC was crashing on a daily basis with no apparent hardware issues (temperatures fine, HWMonitor reporting no problem/memory tests and drive tests showed no problems).
    2. New BIOS 3006 cannot be used because it has the CPU overclocked at idle (at default settings). Hence on an older BIOS, 0802--which worked fine for almost a year).
    3. Reinstallation of Windows (via Windows "Refresh" tool with some apps removed) stopped the daily blue screens.
    4. Now new problem: Sudden restarts at random times.
    Any help/explanations in regards to these issues would rock. Thanks in advance.
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EE Bios 0505
    Processori9 10900X @ 5.0 1.35V VCore
    Memory (part number)GSkill F4-4000C18Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti Kingpin
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Magnitude RGB and Quantum Kinetic D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,195
    Still makes me wonder about the memory kit. That’s a lot of memory. I think it’s*CMK128GX4M8A2666C16? That’s on the QVL, but I wonder about the IMC not being able to handle that much memory. I see you tested it. Perhaps remove half and see if the problem persists? How did you test your memory?
    Mar 2019
    295
    Quote Originally Posted by Hopper64 View Post
    Thanks for replying, Hoppers!! So you think it could be the memory, huh? But if it worked fine for nearly a year and then, bam, it suddenly started crashing? Does memory or the IMC just suddenly fail like that? As for the memory test, it was just a standard memtest from the control panel.
    I suspect it's either the BIOS (which is an old one because 3006 doesnt work properly), some Windows thing, using SLI with DirectX 11 (DirectX 12 does not support SLI)--and hence the Nvidia driver, or maybe a graphics card hardware problem. And it is a real nuisance, man. I'm going nuts.
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,195
    I wasn’t clear on the timeline. Worked ok for a year. That is odd. Memory issue a lot less likely then. Not sure about this.
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,195
    Oh, that standard memory test from the CP is likely not adequate though. Try this*https://www.karhusoftware.com/ramtest/ * * *Or*https://www.memtest86.com/ or both to test memory. I have also used*https://hcidesign.com/
    ROG Enthusiast Array Aysberg PC Specs
    Aysberg PC Specs
    MotherboardASUS ROG RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9-7980XE
    Memory (part number)4 x F4-3200C14-16GTZ
    Graphics Card #1EVGA RTX 2080 Ti XC Ultra Gaming (11G-P4-2382)
    Graphics Card #2EVGA RTX 2080 Ti XC Gaming (11G-P4-2382)
    Monitor1x LG 34GK950G / 2 x HP DreamColor Z27x
    Storage #12 x Samsung NVMe 970 EVO 2TB / Samsung NVMe 3 x 960 EVO 1TB
    Storage #24 x SanDisk SDSSDHII960G
    CPU Coolercuplex kryos NEXT
    CaseLianLi PC-A75X
    Power SupplyCorsair HX1200i
    Keyboard Corsair K95 RGB
    Mouse Roccat LEADR
    Headset AKG K712 + ModMic 5
    OS Windows 10 Pro x64 1909
    Network RouterMikroTik CRS317-1G-16S+RM
    Accessory #1 Mellanox ConnectX-3
    Accessory #2 Asus Hyper M.2 X16 Card
    Nov 2013
    18
    67
    How old is your PSU and what cables do you use to power your GPU. I am running a dual 2080Ti setup too and I needed to change the single GPU power cable ending in two 8-pin (6+2) connectors on my Corsair PSU into two cables for one of my GPUs else my system would reboot under some heavy GPU load situations. The PSU was simply not able to deliver the current. Now everything is rock stable.
    Faulty or unstable memory should lead to an BSOD and not a sudden reboot.
  7. #7
    Mar 2019
    295
    Quote Originally Posted by Aysberg View Post
    CORSAIR AXi Series, AX1600i 1600 watt is my PSU (and has been from day one, nearly a year ago now--when everything worked fine--and the computer was fine for about ten months with no problems). It is less than a year old, and I feed two cables to the each of two 2080 ti in my rig--so four cables in all. I now have a second rig and have put the two GPUs in that rig to test them. The PSU in that rig is 1200 watts and I am only running one cable to each of these cards, and there is no problem.
  8. #8
    Mar 2019
    295
    Just to follow up about this issue, the problem has been corrected. With the installation of the latest chipset driver my rig has stopped suddenly restarting/crashing. Hence, problem solved.
  9. #9
    Mar 2019
    295
    Well, there you have it. Another sudden restart yesterday, so the problem is not solved--and this after being fine for more than a week. Hence, back to collecting more dust for this overpriced, underwhelming heap of junk rig. Sigh.
  10. #10
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    127
    1,858
    Quote Originally Posted by Super Gnome View Post
    Rollback to the last Windows kernel if you've recently updated. The latest update for W10 has caused a few issues for some users. Failing that, install a dummy OS of W10 and see if the problem persists there.
    Check event viewer for the debug codes, may possibly give you some indication on what's causing the crashing.
