Results 1 to 2 of 2
    ROG Enthusiast Array tunc8686 PC Specs
    tunc8686 PC Specs
    MotherboardAsus Rog Maximus X Hero
    Processor8700K @5Ghz
    Memory (part number)Corsair Dominator 32GB (4*8Gb) 3200Mhz
    Graphics Card #1Asus Rog Strix 1080Ti OC
    MonitorAsus VG248QE
    Storage #1Samsung 950Pro 512Gb
    Storage #2Samsung 850Pro 256Gb
    CPU CoolerEKWB Costum Cpu Block
    CaseThermaltake View 71
    Power SupplyEvga Supernova 1000P2
    Keyboard Steelseries 7G
    Mouse Steelseries Rival 700
    Headset Corsair Void Pro
    Mouse Pad Steelseries QMass
    OS Win10
    tunc8686's Avatar
    Sep 2014
    11
    63
    Asus Rog Xi Formula Z390 (EKWB Water Block Spare part)
    Hey Guys ,
    i have xi formula z390 and i have little bit problem for water block ( plastic cover) i added picture . fitting area also is plastic materiel and now i have some
    fittings locations are no longer solid . where can i buy only this cover ? Does Asus help me ? or i want to buy all waterblock area
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,843
    *****Thread moved. Not a service inquiry. Must have existing RMA*****
    Hi tunc, if the part is failing due to normal usage and you are under warranty you should RMA the board. If not then most likely you would need to find that on Ebay.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
