Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD Samsung 970 EVO Plus 500GB
    Storage #2SSD Samsung 960 EVO 250GB | SSD Corsair MP510 240GB | SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 21H1/VB/19043.x
    MoKiChU's Avatar
    Aug 2013
    304
    565
    [DRIVERS] Realtek Audio (MB | Intel 6x/7x/8x/9x/1xx)
    Hi everyone,
    - Realtek High Definition Audio Drivers (HDA - ASUS ROG SSx MB) :
    Drivers : 6.0.8967.1 WHQL [09/06/2020]
    Download : Link
    ASUS ROG SS1/SS2 motherboards :
    Install/Update Process :
    CLEANUP
    /!\ If you already had Realtek (HD) Audio Driver, Sonic Suite II and/or Sonic Radar I/II installed /!\
    Uninstall them (Start > Settings > Apps) then restart your PC
    - Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
    a-volute | avolute | dts | hdx | realtek
    - Check the box "Force Deletion" then click on the "Delete Driver" button then restart your PC
    INSTALL
    - Launch "Setup.exe" > "Next" > The installer will ask you to restart your PC > "Finish"
    - Install Sonic Suite II v2.2.3901.0 (Sonic Studio II & Sonic Radar II) : Link
    UPDATE
    - Launch "Setup.exe" > "Next" > The installer will ask you to uninstall your current drivers > "Next"
    - Then it will ask you to restart your PC > "Finish"
    - Then at startup it will automatically launch the installation of new drivers > "Next"
    - Realtek High Definition Audio Drivers (HDA - ASUS ROG/TUF/PRIME DTS&RTK MB) :
    Drivers : 6.0.9132.1 WHQL [16/03/2021]
    Download : Link
    ASUS TUF/PRIME DTS Studio Sound motherboards :
    CLEANUP
    /!\ If you already had Realtek (HD) Audio Driver, DTS Studio Sound installed /!\
    INSTALL
    - Install DTS Studio Sound v1.0.2000.0 : Link
    UPDATE
    ASUS ROG/TUF/PRIME Realtek motherboards :
    CLEANUP
    /!\ If you already had Realtek (HD) Audio Driver installed /!\
    Uninstall it (Start > Settings > Apps) then restart your PC
    INSTALL
    UPDATE
    OS requirements : Windows 10 64 bit 1803/RS4/17134.x or more recent.
    Hardware requirements : ASUS ROG/TUF/PRIME motherboards with Intel 6x/7x/8x/9x/1xx series chipsets.
    Note : In order to know which Install/Update process to use, match the audio specifications of your motherboard with the apps or ask me.
    TIPS :
    If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
    Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
    If you want better interrupts delivery latency
    Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
    MSI Mode Utility (Right click on "MSI_util_v3.exe" > Run as administrator).
    If you experience crackling, popping, audio stutter
    Disable Fast Startup or totally disable hibernation (Fast Startup included).
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMT32GX4M4Z3200C16
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 970 Evo 1TB (Boot) & 970 EVO 2TB (Scratch)
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300 + Corsair MM800 Polaris (EU)
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit, 2x LS100 RGB kit + 450mm expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    38
    237
    @MoKiChU sent you a PM regarding audio driver. Hoping you can assist
    ROG Enthusiast Array BJBBJB PC Specs
    BJBBJB PC Specs
    MotherboardMaximus VIII Hero
    Memory (part number)G.Skill F4-2666C15Q-32GRR
    Graphics Card #1GTX560
    Storage #1Samsung Pro 950 SSD
    Storage #2Multiple Seagate Barracuda Drives
    CaseAntec P182
    Power SupplyEnermax Modu 82
    Mouse Logitech MX Master Wireless
    Headset/Speakers Logitech 5.1
    OS Windows 10
    Oct 2015
    57
    Is there any difference between the 4/20 and 4/24 links? I get the same filename for the HDA - ASUS ROG/PRIME/TUF DTS&RTK driver? I am the one with the Maximus Hero VIII and was just getting around to downloading the drivers.... Guess I will go without sonic suite 2.
    I realized it was so long since I looked at this I was actually running the version 6.0.1.8468 drivers from the Asus driver page (didn't even remember doing that update a while ago) which did not give me 5.1 audio in the supremeFX tab test although I get pseudo 5 speaker sound from stereo. Even without Sonic Studio 2. Very strange. Will I still get fake 5.1 from stereo with this driver and without Sonic Studio 2? And I assume it will bring back my "real" 5.1 audio where the test will work in all 5.1 speakers?
    I am assuming since I never had the DTS stuff nor do I need it, if I do not want to worry about Sonic Suite 2, I can just use this driver and not install all the DTS stuff? So just use this uninstall/install process?
    NSTALL
    /!\ Only if you already had Realtek HD Audio Driver installed /!\
    1) Uninstall it (Start > Settings > Apps) then restart your PC
    2) Launch Driver Store Explorer > Check the boxes of all versions of drivers which .inf starts with (if you find them) :
    dts | a-volute | avolute | hdx | realtek
    3) Check the box "Force Deletion" then click on the "Delete Package" button then restart your PC
    4) Perform a cleanup of the registry (with CCleaner Free or others)
    Thanks,
    BJBBJB
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    304
    565
    Quote Originally Posted by BJBBJB View Post
    NSTALL
    Thanks,
    BJBBJB
    You need Realtek High Definition Audio Drivers (HDA - ASUS ROG/PRIME/TUF MB) for your ASUS ROG Maximus VIII Hero. Follow scrupulously the INSTALL process (with cleanup step) of ASUS ROG SS1/SS2 motherboards category.
    Here is a official description of what functions SS2 have : https://www.asus.com/support/FAQ/1033006/
    The configuration of the audio channels (Stereo, 5.1, etc.) is done via Realtek HD Audio Manager/SupremeFX (via tray icon or via Control Panel).
    The configuration of the Surround/Upmix is done via Sonic Studio II.
    BJBBJB PC Specs
    CaseAntec P182
    OS Windows 10
    Oct 2015
    57
    Quote Originally Posted by MoKiChU View Post
    20/04/2020 : AUDIO_Realtek_HDA_ASUS_ROG-PRIME-TUF_DTS&RTK_v6.0.8899.1
    24/04/2020 : AUDIO_Realtek_HDA_ASUS_ROG-PRIME-TUF_DTS&RTK_v6.0.8924.1
    You need Realtek Audio Drivers (HDA - ASUS ROG SSx) for your ASUS ROG Maximus VIII Hero. Follow scrupulously the INSTALL process (with cleanup step & SS2/SR2 apps) of ASUS ROG SSx motherboards category.
    If on the other hand if you are not wanting to use SS2/SR2 apps (and therefore you don't want SS2 Surround/Upmix feature), you can use Realtek HD Audio Drivers (HDA - ASUS ROG/PRIME/TUF DTS&RTK) by following scrupulously the INSTALL process (with cleanup step) of ASUS ROG/PRIME/TUF RTK motherboards category.
    Thanks. I got all that down😀.
    Just asking if there is a difference between the download link at the top of the post and the second download link. I get the same filename.
    Also, I am aware how to setup 5.1 but it has not worked with my last 2 driver versions. Wonder if this will fix that.
    Thanks a lot!
    BJBBJB
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    304
    565
    I understand now what you mean, the fact that you talk about date ("the 4/20 and 4/24 links") has misled me.
    These are the same links.
    You do not seem to know my way of proceeding : The first post of my threads is edited over the water and always includes the latest drivers packages versions and all the install/update processes, while my update posts are there for indicate the release of the latest drivers package version and indicates that the first post of the thread is updated accordingly.
    I hope I was clear enough.
  7. #7
    BJBBJB PC Specs
    CaseAntec P182
    OS Windows 10
    Oct 2015
    57
    100% clear, thanks!
    Any thoughts on these drivers fixing my 5.1 issue or is that luck of the draw? I am leaning towards the "non-SS2" ones due to the vulnerability...
    BJBBJB
  8. #8
    ROG Member Array Gentleman PC Specs
    Gentleman PC Specs
    MotherboardMAXIMUS VIII GENE
    ProcessorINTEL i7 6700K
    Memory (part number)G.SKILL 3000Mhz 16 GB (2x8)
    Graphics Card #1ASUS RX 560 STRIX O4G
    Sound CardSupremeFX 2015
    MonitorASUS ROG STRIX XG32VQR
    Storage #1Crucial MX200 240GB
    Storage #2Crucial MX500 500GB, 2x WD Black 500GB
    CPU CoolerCorsair H100i v2
    CaseCorsair Air 240
    Power SupplyBeQuiet 500W Pure Power
    Keyboard ASUS ROG
    Mouse Logitech MX-518
    Mouse Pad ASUS ROG
    OS Windows 10 PRO x64
    Sep 2016
    19
    will this drv work with maximus VIII gene?
  9. #9
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    304
    565
    Quote Originally Posted by Gentleman View Post
    Yes of course :
    You need Realtek High Definition Audio Drivers (HDA - ASUS ROG/PRIME/TUF MB) for your ASUS ROG Maximus VIII Gene. Follow scrupulously the INSTALL process (with cleanup step) of ASUS ROG SS1/SS2 motherboards category.
  10. #10
    New ROGer Array SteverinoLA's Avatar
    Jan 2020
    38
    32
    I'm not up to date on my ROG models. Do any of these drivers work for STRIX Z390-F?
