Rampage V Edition 10 - Will not boot
Amerifaxx
Rampage V Edition 10 - Will not boot.
The Start & Reset lights up. Also, the PCIe slots light up. The fans do not run. I hear no sound. I'm clueless.
Bob
Amerifaxx
I should have mentioned I have completely rebuilt the computer.
Bob
davemon50
Level 11
Unseat and firmly reseat your 24-pin cable to the motherboard and the PSU. Same for the 8-pin cable as well (they both are required connections). There's not much information in your post, but to me it sounds like a power delivery issue. Ensure you connected your video card power cable(s) correctly too.
Davemon50
Amerifaxx
>> Ensure you connected your video card power cable<
Yes. That was surely one of my problems. I fixed that. Now I'm at error AA, "Ensure you connected your video card power cable". I'm using an Asus Strix Director II. I have the following connections to the Video Card:
3 Pin, 4
Also, when I am stopped at Code AA my PCIex16 Lane Switch lights have two blocks of light, page 1.3 of manual, Upper block light4 is stead on. Lower block 1-2-3-4 light are stead on.
Is there a way to check the memory, motherboard an cpu, seperatly?
My System
Rampage V Edition 10 - LGA 2011-v3 Socket
Intel i7 XC-Series Processor
Chipset: Intel X99
Memory: g.Skill TridentZ DDR4-3333 CL16-18-38, 1.35V F4-3333C16Q2-128GTZKW
Samsung M.2: V-NAMD SSD 512gb (8 Sticks)
Power Supply: Corsair HX860i
DVD: Asus BW-16D1HT/BLK/G/AS
Seagate 1-12TB BarraCuda Pro
Seagate 1-4TB BarraCuda Pro
Asus Monitors: 32 Inch, 29 Inch, 29 Inch
As yet I have not installed the operating system but it will be Windows 10 Pro.
Bob
