Results 1 to 2 of 2
    ROG Junior Member Array
    Jan 2016
    2
    Help, Rog Front Base in board Strick z390F, How do I connect it?
    Cheers
    I recently damaged an asus z290. To replace it I have thought of a Strik z390F. In my previous board I had the Rog Front Base connected in the connector of the "Rog Ext" board. The z390 no longer has this connector.
    I would like to know if it is possible to connect the Rog Front Base to the z390 board in some way, because I love the front and it is a bummer not to be able to place it.
    See if in this forum you can help me, because I have already sent two emails asking Asus about this topic and I do not receive a reply.
    Thank you
    ROG Guru: White Belt Array AS185 PC Specs
    AS185 PC Specs
    Laptop (Model)Lenovo Y700-17ISK
    MotherboardZenith Extreme
    ProcessorAMD Threadripper 1950X
    Memory (part number)4 x G Skill F4-3200C16D-32GTZKW @ 3200MHz
    Graphics Card #1Nvidia Titan RTX
    MonitorSamsung Odyssey G5 LC34G55T
    Storage #16 x PNY 2TB XLR8 CS3030
    Storage #23 x 1TB Crucial MX500
    CPU CoolerThermaltake Water3.0 Ultimate
    CaseCorsair Obsidian 900D
    Power SupplyCooler Master MasterWatt Maker 1200W
    Keyboard Razer Ornata Chroma
    Mouse Razer Mambe TE / Logitech USB TrackMan Wheel
    Mouse Pad steelseries Cyberpunk 2077 edition
    Headset/Speakers Onkyo HT-S3910
    OS Windows 10 Home x64
    Accessory #1 Asus Hyper M.2 X16 Card V2
    Accessory #2 Asus DIMM.2 card in slot
    Accessory #3 KingMod Corsair 900D Silencing Kit
    AS185's Avatar
    Feb 2020
    21
    123
    Your motherboard has the AAFP connector. But I don't see anything for the ROG_EXT connector. You might have to consider buying a compatible motherboard for this device.
