Armoury Crate and Monitors
BigDaddyXD
I bought the PG27VQ Monitor that also supports AURA RGB. Because my other hardware AURA RGB only works fine with Armoury Crate, this is the Aura Software that i am using.
Now i realized that monitors do not seem to be supported in Armoury Crate? How can i configure my Monitor RGB right now? Because Armoury Crate and ROG Armoury don't work with each other! And i really wanna use the features i payed for.
1. When will Armoury Crate support ASUS Monitors as well?
2. How can i tempoarily configure my new Monitors RGB in the meantime?
Thanks for any answer.
extrimal
A reasonable question for such a premium monitor
I also ask the same as above
Re
Mine does work in armoury crate only thing is the as soon you choose the rainbow effect the transitions aren’t smooth. But if you guy want any help join the asus discord*
