Results 1 to 3 of 3
    New ROGer Array
    Apr 2020
    1
    Router start dropping wifi devices.
    I have had my AX11000 router for 2 weeks now, and about 1 week into having it installed I have been experiancing wifi devices dropping off and in the log I see the following.
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind 2C:F4:32:00:2A:C4, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(427): wl0.3: Auth 2C:F4:32:00:2A:C4, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:16 kernel: DROP IN=eth0 OUT= MAC=d4:5d:64:31:3a:d0:28:52:61:f0:64:19:08:00 SRC=172.217.10.98 DST=XXX.XXX.XXX.XXX LEN=108 TOS=0x00 PREC=0x00 TTL=123 ID=50340 PROTO=TCP SPT=443 DPT=50058 SEQ=2164081706 ACK=3387766622 WINDOW=254 RES=0x00 ACK PSH URGP=0 OPT (0101080A1F2D8C36142A3957) MARK=0x8000000
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(427): wl0.3: Auth CC:9E:A2:57:0E:80, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind B8:2C:A0:13:EA0, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(427): wl0.3: Auth B8:2C:A0:13:EA0, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:16 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Class 2 frame received from nonauthenticated station (6)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Class 2 frame received from nonauthenticated station (6)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(427): wl0.3: Auth CC:9E:A2:57:0E:80, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind B8:2C:A0:18:AC:70, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(427): wl0.3: Auth B8:2C:A0:18:AC:70, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind DC:4F:22:64:66:3F, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(427): wl0.3: Auth DC:4F:22:64:66:3F, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind 20:3D:BD:67:4B:54, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:17 wlceventd: wlceventd_proc_event(427): wl0.3: Auth 20:3D:BD:67:4B:54, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Class 2 frame received from nonauthenticated station (6)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(427): wl0.3: Auth CC:9E:A2:57:0E:80, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind BCD:C2:19:28:C0, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(427): wl0.3: Auth BCD:C2:19:28:C0, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:18 kernel: DROP IN=eth0 OUT= MAC=d4:5d:64:31:3a:d0:28:52:61:f0:64:19:08:00 SRC=45.141.84.30 DST=XXX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=52450 PROTO=TCP SPT=48460 DPT=1975 SEQ=214459226 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind CC:9E:A2:57:0E:80, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind DC:4F:22:64:64:8D, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(427): wl0.3: Auth DC:4F:22:64:64:8D, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:18 kernel: DROP IN=eth0 OUT= MAC=d4:5d:64:31:3a:d0:28:52:61:f0:64:19:08:00 SRC=172.217.10.98 DST=XXX.XXX.XXX.XXX 5 LEN=108 TOS=0x00 PREC=0x00 TTL=123 ID=43823 PROTO=TCP SPT=443 DPT=50042 SEQ=1084107140 ACK=2640493579 WINDOW=389 RES=0x00 ACK PSH URGP=0 OPT (0101080AABB7D7BC142A42EA) MARK=0x8000000
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind B8:2C:A0:18:BA:CA, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:18 wlceventd: wlceventd_proc_event(427): wl0.3: Auth B8:2C:A0:18:BA:CA, status: 0, reason: d11 RC reserved (0)
    Apr 24 13:32:19 wlceventd: wlceventd_proc_event(392): wl0.3: Deauth_ind 2C:F4:32:00:2A:C4, status: 0, reason: Unspecified reason (1)
    Apr 24 13:32:19 wlceventd: wlceventd_proc_event(427): wl0.3: Auth 2C:F4:32:00:2A:C4, status: 0, reason: d11 RC reserved (0)
    A reboot will clear this up, and thoughts?
    I have a AX11000, RT-AC68U and RT-AC5300, in a mesh setup. The AX11000 is the master.
    A little more info. the router stays up and running, but the number of wifi connected devices goes from about 61 down to about 37, and king of hangs there. I also see the number of connected devices move from the AX11000 device to the other MESH nodes, not something that usually happens. Device that would normally not be connected to the other nodes.
    New ROGer Array
    Apr 2020
    2
    I had exactly the same set up and problems, try deleting RT AC5300 and use only AC68U as Aimesh node. All should be fine thereafter, hope so. From my experience, AX11000 doesnt pair well with RT AC5300 as node, randomly forcing AX11000 to auto reboot.
    New ROGer Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardCreative Labs Sound Blaster AE-9
    MonitorSamsung 32" UH750 QLED UHD Monitor
    Storage #1Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerCooler Master MLX-D36M-A20PC-R1 w/ Noctua NF-F12 industrialPPC-2000 IP67 PWM x3 Fans
    CaseLian Li PC-011 Dynamic XL (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad Razer Vespula V2 Mousepad
    Headset/Speakers Creative GigaWorks T40 Series II
    OS Windows 10 Pro for Workstations
    Network RouterROG Rapture GT-AC5300
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 Logitech BRIO ULTRA HD PRO WEBCAM
    Jesseinsf's Avatar
    Mar 2019
    22
    220
    Same thing happens with my ROG Rapture GT-AC5300
    Same thing happens with my ROG Rapture GT-AC5300 and I only have no more than 15 devices connected. No Mesh network. I live in a 1400 square foot apartment. the router is in the center of the apartment.
