Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 33
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 Pro 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    396
    638
    [FIRMWARE] Intel ME (Z170/Z270/Z370)
    Hi everyone,
    - Intel ME Consumer Firmware :
    Firmware : 11.8.86.3909 [14/03/2021]
    Download : Link
    Check/Update Process :
    Check current version : Right click on "Check.cmd" > Run as administrator
    Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
    OS requirements : Windows 10 64 bit or more recent.
    Hardware requirements : Motherboards with Intel Z170/Z270/Z370 chipset.
    ROG Member Array
    Jan 2016
    20
    7
    MoKiChU, thank you very much! I've seen version 11.8.71.3630 on win-raid forum but there are a lot of problems and bad responses on it and i didn't dare to update from your previous version 11.8.70.3626, decided to wait update from you. Now just updated to 11.8.77.3664 on z270 Maximus IX Hero - everything is good and even slightly better than before!
    ROG Member Array
    Nov 2019
    5
    Hello! Is there a way to roll back the firmware? after the update, the cpu is loaded to 100% in the Call of Duty War Zone game. maybe of course this is due to something else) I also updated all the latest drivers and BIOS. also in the game there was a patch) just interestingly you can somehow roll back)
    cpu 8700k (using google translator)
    ROG Member Array
    Nov 2019
    5
    Quote Originally Posted by MoKiChU View Post
    Like any firmware, it is very complicated to rollback.
    However, it is unlikely that updating the Intel ME firmware could have caused your issue (I also use a Z370 motherboard (ROG Strix Z370-F) with this latest Intel ME firmware with CPU 8700K, and I also play CoD MW/WZ and I have no such problem).
    Thanks for the answer and for everything you do for us! I will look for solutions to my problem; I may need to reinstall Windows; I have build 19041.207. Another question is, is there any rule about the order in which drivers are installed on a clean system?
    ROG Member Array
    Nov 2019
    5
    No there is not really a rule apart from the fact that it is optimal to install the chipset drivers first. So, you can do it this way :
    1) Chipset/Ethernet/MEI/SATA drivers (Intel) : [DRIVERS] Intel Chipset/Ethernet/MEI/SATA (1xx/2xx/3xx/4xx)
    2) GPU drivers (NVIDIA DCH or AMD DCH)
    3) Audio drivers (Realtek UAD) : [DRIVERS] Realtek Audio (UAD)
    4) Others drivers & accessories drivers that you have
    Thank! I will adhere to your recommendations.
    ROG Enthusiast Array
    Oct 2012
    45
    can I install this on a maximus VIII hero alpha?
    Also, does it matter which BIOS I am running?
  7. #7
    Oct 2012
    45
    Thanks
  8. #8
    ROG Guru: White Belt Array claudej PC Specs
    claudej PC Specs
    MotherboardMaximus VIII Gene
    ProcessorIntel 7700K
    Memory (part number)2*8GB G.SKILL RipJaws IV
    Graphics Card #1Intel HD Graphics 630
    MonitorLG 65E7V
    Storage #1Intel 660P 2.0TB M.2 SSD
    Storage #2Seagate Exos 16TB
    CPU CoolerID-Cooling IS-50
    CaseSilverstone SG04B-H mATX
    Power SupplyThermaltake London 550W
    Keyboard Logitech K800
    Mouse Logitech Performance Mouse MX
    OS Windows 10 64bit
    Accessory #1 LG CH08LS10 Blu-Ray
    Sep 2015
    83
    Thank you
  9. #9
    ROG Member Array dancefly's Avatar
    Nov 2018
    18
    Thank you
    Thanks for your work MoKiChU. Can i update it directly from 11.8.50.3470 to 11.8.77.3664 ?
  10. #10
    Nov 2018
    18
    thanks
    Yes, of course.
    thank you for the quick reply and supporting us with the new updates.
    have a nice day and stay healthy !
