Who has successfully ran xmp on Z390 with 4000+ MHZ ram
FastSmitty
I have seen lots of threads about xmp profiles not working on 3733mhz + on XMP profile without any adjustments. So I would like to see who has successfully ran their xmp profile on 4000+ MHZ without any adjustments at all.
thanks
7 REPLIES 7
elkhog
I have have been able to run xmp on 4266 gskill on apex xi z390 with no problem. I have some 4800 gskill that i can run real stable at 4300 and most at 4600 with out crash.http://www.3dmark.com/pr/220866 http://www.3dmark.com/fs/21760076
Arne_Saknussemm
Level 40
I ran 4000MHz on a Gene with a couple of 9900KSs...XMP and up and running...
Most other times I had to adjust something
Carlyle2020
Reading this forum for years it seems corsair sticks run smoother in general with xmp than gskill.
Best Regards
Carlyle
Silent_Scone
Super Moderator
Hello,
Here is 4x8GB 4266 running stable on the Maximus Formula XI.
84735
I have run Corsair LPX 4600MHz 1.5V modules in XMP at default settings stable on Maximus XI Apex board with 1401 BIOS.
84764
bass_junkie_xl
Level 11
Asus XI CODE Z-390
Team group xtreeme 4133 mhz cl-18-18-18-38 ( 42 ns ) @ manual 4200 mhz cl -17-17-17-32 ( tightned all sub timings ! ) 😄 sorry MR 4600 mhz above me u need to tweak .
i had my 4000 mhz cl17 oc from 3000 mhz cl 14 on asus x hero z370 no issues at all .
84765
Rig # 1 - 14900Ks SP-118 | 87 MC @ 6.0 GHZ | 5.2 R | 4.7 E | DDR5 48GB @ 8,600 c36 | Strix RTX 4090 | PG27AQN 1440P 27" 360 Hz G-Sync ULMB 2
Rig # 2 - 14900K-SP-120 | 89 MC @ 5.9 GHZ | 5.2 R | 4.7 E | DDR4 32GB @ 4,300 c15 | Strix RTX 3080 | Aoc 1080P 25" 240 Hz G-Sync
+1 you do get much better results tweaking.
I'v tried most of the 2x8GB Extreme Tweaker\DRAM Memory Presets in 1401 BIOS with the Corsair LPX 4600 kit.
Few days ago started running 1502 BIOS, and 2x16GB Samsung Double-Side modules. F4-3200C14D-32GTZSK kit,..
running @ 1.35V they will do 3733MHz,.. this weekend going to bump up the voltage, would like to see 4000MHz +
84816
