Results 1 to 9 of 9
    ROG Guru: Black Belt Array Hopper64 PC Specs
    Hopper64 PC Specs
    MotherboardAsus R6EE Bios 0702
    Processori9 10900X @ 5.0 1.37V VCore
    Memory (part number)GSkill F4-4000C18Q2-64GTZR
    Graphics Card #1EVGA 2080 Ti
    Sound CardCreative SB AE7
    MonitorAsus ROG PG349Q
    Storage #1Intel 905p M.2 360G
    CPU CoolerEKWB Magnitude RGB and Quantum Kinetic D5
    CasePhanteks Enthoo Elite
    Power SupplyCorsair AX1600i
    Keyboard Asus Strix Flare
    Mouse Asus ROG Gladius II Origin
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,212
    Upcoming Maximus xii extreme and PCIe lanes
    With the new z490 chipset, looks like it’s still 16 PCIe lanes off the cpu. A single video card will run at x16 unless the DIMM.2 is populated? That’s my question. Will it drop to x8 if you use a m.2 nvme drive in the DIMM.2? If you use any other m.2 connection on the motherboard to run a nvme drive then it will use the pch and a single video card will still work at x16?
    The very top slot on the M12E appears to be a x4 pch connection. Is this correct? Thanks.*
    *https://www.asus.com/Motherboards/RO...S-XII-EXTREME/
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,212
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,212
    Manual came out today. Looks like using the DIMM.2 drops the video card to x8.
    ROG Guru: Yellow Belt Array Ch3vr0n PC Specs
    Ch3vr0n PC Specs
    MotherboardAsus Maximus XI Formula
    ProcessorCore i9 9900k @ 4.7GHZ (XMP)
    Memory (part number)CMT32GX4M4Z3200C16
    Graphics Card #1Asus Strix GTX 1080 A8G
    Sound Cardon board
    MonitorASUS VG278HR & ASUS VK278Q
    Storage #1Samsung 970 Evo 1TB (Boot) & 970 EVO 2TB (Scratch)
    Storage #23X HGST 10TB, 1x HGST 4TB
    CPU CoolerScythe Mugen 5 PCGH
    CaseCooler Master Cosmos II
    Power SupplyCorsair AX860i
    Keyboard Corsair k95 RGB Platinum
    Mouse Corsair M65Pro RGB
    Headset Corsair Voide Wireless SE
    Mouse Pad Corsair MM300 + Corsair MM800 Polaris (EU)
    Headset/Speakers Logitech Z-906
    OS Windows 10 Pro x64
    Network RouterNetgear XR500
    Accessory #1 Xbox One Elite Wireless Controller
    Accessory #2 2X Corsair LL140, 4x Corsair LL120
    Accessory #3 1x Corsair LED RGB Pro expansion kit, 2x LS100 RGB kit + 450mm expansion kit
    Ch3vr0n's Avatar
    Nov 2012
    38
    237
    Quote Originally Posted by Hopper64 View Post
    Which shouldn't have any noticeable performance issues whatsoever. Most (if not all) cards run just fine at optimel efficiency at x8
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,212
    Quote Originally Posted by Ch3vr0n View Post
    Yes. I agree, but there are still limitations with the pcie lane allocation even in this generation that make Intel X299 or AMD offerings more attractive.
    ROG Guru: Yellow Belt Array Enderwiggin03 PC Specs
    MotherboardROG STRIX Z390-E Gaming
    ProcessorIntel Core i9 9900k @ 5.1Ghz on all 8 cores 1.355v
    Memory (part number)F4-4266C19D-16GTZR @ 4000Mhz CL16-17-17-35 1.45v
    Graphics Card #1EVGA RTX 2070 XC Ultra
    Sound CardCreative Sound Blaster X AE-5
    MonitorASUS VG248QE
    Storage #1Samsung 970 Evo 500GB m.2
    Storage #2Samsung 860 Evo 1TB SATA
    CPU CoolerEVGA CLC280 with 4x NF-A14 iPPC-3000 PWM (push/pull)fans
    CaseFractal Design R6
    Power SupplyEVGA G3 1000w
    Keyboard Logitech G513 Carbon
    Mouse Logitech G703
    Mouse Pad Logitech Poweplay
    OS Windows 10 Home x64
    Nov 2018
    148
    I was under the impression Z490 had more PCI-E lanes.
  7. #7
    Hopper64 PC Specs
    OS Windows 10 64
    Hopper64's Avatar
    Nov 2012
    47
    2,212
    I think it's 16 through the CPU and 30 plus via PCH.
    https://www.intel.com/content/www/us...i9-10900k.html
  8. #8
    ROG Guru: Yellow Belt Array btrach144 PC Specs
    btrach144 PC Specs
    MotherboardASUS Maximus XII Extreme
    ProcessorIntel i9 10900K @ 5.1 GHz
    Memory (part number)32 GB G.Skill DDR4 4000MHz C17
    Graphics Card #1EVGA 2080Ti FTW3 Hydro Copper
    MonitorASUS PG27UQ
    Storage #1x2 Samsung 970 Pro 1 TB in RAID 0
    Storage #2Samsung EVO 850 1 TB
    CPU CoolerCustom EK loop
    CaseCorsair 750D
    Power SupplyROG THOR 1,200W
    Keyboard Logitech G915
    Mouse Logitech G903 PowerPlay
    Headset Logitech G935
    Mouse Pad Logitech Powerplay
    Headset/Speakers Logitech Z905 5.1 surround
    OS Windows 10 (2004)
    Network RouterASUS AX11000
    Jun 2014
    140
    We need more lanes. It's crazy Intel is still playing cheap on this. I'd upgrade from my 9900K but there's nothing worth getting by upgrading.
    Not to mention, the Extreme is $250 (50%) more than the previous gen.
    AMD 4000 series looks to be in my future.
  9. #9
    ROG Member Array DM039 PC Specs
    DM039 PC Specs
    MotherboardZ390 XI Extreme
    Processori7 9700k
    Memory (part number)8pack 4133mhz Team Group
    Graphics Card #1MSI 2080TI gaming x trio
    MonitorAsus XG258q
    Storage #1m.2 970 evo 250GB
    Storage #2m.2 970 evo 500GB
    CPU CoolerCorsair H150i
    Power SupplySeasonic 1000W
    Nov 2017
    17
    It was like that even with previous gen. If you have dedicated m.2 then dimm.2 will cut pcie lanes.
    Now the bigger question is, how that will work on XII Apex. as it has only 1 m.2 slot, and dimm.2, according to other mobos it will be only possible to use single m.2 without affecting gpu pcie.
    Prev gen had only dimm2, while both slots in dimm2 were populated it didnt cut pcie lanes.
