Results 1 to 10 of 39
05-10-2020 09:39 PM #1
MoKiChU PC Specs Motherboard ASUS ROG Strix Z370-F Gaming Processor Intel Core i7-8700K Memory (part number) Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB) Graphics Card #1 ASUS ROG Strix GTX 1080 Ti OC Monitor ASUS ROG Strix XG35VQ Storage #1 SSD NVMe Samsung 970 EVO Plus 500GB Storage #2 SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB CPU Cooler Cooler Master ML240L RGB Case BitFenix Enso Power Supply Corsair TX850M (850W) Keyboard Logitech G413 Mouse Logitech G502 Headset/Speakers Logitech Z333 OS Windows 11 Pro 22H2
- Join Date
- Aug 2013
- Reputation
- 507
- Posts
- 614
Hi everyone,
- Realtek Ethernet Drivers (Drivers Only) :
Drivers - Windows 11 : 11xx.11.1206.2022 WHQL [06/12/2022]
Drivers - Windows 10 : 10.63.1014.2022 WHQL [14/10/2022]
Download - Windows 11 : Link
Download - Windows 10 : Link
Install/Update Process :
- Press Windows key + X > Device Manager > Right-click on your Realtek Ethernet device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (ETHERNET_Realtek_v...) > Next
Drivers - 8852BE : 6001.15.133.0 WHQL [01/11/2022]
Drivers - 8723DE/8821CE/8822xE : 2024.10.138.3 WHQL [11/08/2022]
Drivers - 81xxEE/8723BE/88xxAE : 2024.0.4.209 WHQL [15/03/2021]
Download - 8852BE : Link
Download - 8723DE/8821CE/8822xE : Link
Download - 81xxEE/8723BE/88xxAE : Link
- Press Windows key + X > Device Manager > Right-click on your Realtek WiFi device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (WiFi_Realtek_v...) > Next
Drivers - 8852BE : 1.9.1051.3009 WHQL [21/09/2022]
Drivers - 8723DE/8821CE/8822xE : 1.9.1051.3007 WHQL [18/11/2022]
Drivers - 81xxEE/8723BE/88xxAE : 1.7.1019.3002 WHQL [02/07/2019]
- Press Windows key + X > Device Manager > Right-click on your Realtek Bluetooth device > Update driver > Browse my computer for driver software
- Browse... > Select the extracted drivers folder (BT_Realtek_v...) > Next
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Realtek Ethernet/WiFi/Bluetooth controller.
TIPS :
If you want to manage the drivers (remove old/unused drivers for example) that you have in your Windows DriverStore
Use Driver Store Explorer (Right click on "Rapr.exe" > Run as administrator).
If you want better interrupts delivery latency
Enable MSI (Message Signaled-based Interrupts) mode on all your supported devices (see the column "supported modes") with
MSI Mode Utility (Right click on "MSI_Mode_Utility_v3.exe" > Run as administrator).Last edited by MoKiChU; 01-30-2023 at 06:54 PM.
06-17-2020 03:45 PM #2
piratino PC Specs Laptop (Model) OMEN by HP [15-dh0057nl] Motherboard ASUS ROG STRIX Z590-I GAMING WIFI Processor Intel Core i711700K Memory (part number) G.Skill Ripjaws V 32GB (2x16GB) DDR4-3000MHz CL15-15-15-35 1.35V - F4-3000C15D-32GVR Graphics Card #1 ASUS GeForce® RTX 3070 Noctua OC Edition 8GB GDDR6 Sound Card Headset: Creative Sound BlasterX G1 Portable 7.1 Soundcard /Speakers: [motherboard integrated] Monitor HP OMEN X 27 Storage #1 OS: FireCuda 520 SSD 500GB [ZP500GM30002] /Game: FireCuda 520 SSD 1TB [ZP1000GM30002] Storage #2 Data: Seagate FireCuda Solid State Hybrid Drive 2TB (SSHD) [ST2000DX002] CPU Cooler Noctua NH-D15S w/ extra Noctua NF-A15 PWM fan in push-pull configuration Case SilverStone SG10 [SST-SG10B (Black)] Power Supply Corsair SF750 Platinum Keyboard Work: Logitech K800 Wireless Keyboard /Game: Keyboard E-YOOSO K-700 [CherryMX Silver Speed Switches] Mouse Work: Logitech Wireless Mouse MX Master 2S /Game: Logitech G-Pro X ULTRALIGHT Wireless Headset Game: Superlux HD 668B Mouse Pad ARTISAN Ninja FX Raiden MID [Black-XL] Headset/Speakers Room/Ambient: Creative Labs DTT2200 Desktop Theater Digital 5.1 Computer Speaker System OS Microsoft Windows 11 Professional
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
Amazing! Thank you!!!
06-17-2020 04:25 PM #3
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
06-17-2020 05:05 PM #4
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
I forced the driver 1.8 just before seeing this post.
Did it manually selecting the v4.2 as my motherboard specs. Installed it and seemed to work, but as it is tricky (and immagine will NOT bring that much of improvements -- in case YES, please tell us about it), I switched to the 1.7 you just posted. Every thing perfect!
Need to say that the "The operation completed successfully" came up after a while, and not immediately, so it is metter to wait a bit before thinking it was not installed.
06-17-2020 08:45 PM #5
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
09-23-2020 10:55 AM #6
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
09-23-2020 12:51 PM #7
- Join Date
- Sep 2018
- Reputation
- 81
- Posts
- 176
11-07-2020 04:52 PM #8
- Join Date
- Jun 2017
- Reputation
- 10
- Posts
- 2
Thanks for the drivers.
12-09-2020 11:17 PM #9
Da-BOSS PC Specs Laptop (Model) ASUS TUF A15 - FA506IU Motherboard AMD K17.6 FCH, AMD K17.6 IMC Processor AMD Ryzen 7 4800H with Radeon Graphics Memory (part number) G.SKILL [Samsung Die] DRR4 - 3200Mhz CL18 (18-19-19-36) - 32GB(16GBx2) - Using Thaiphoon Burner Tool Graphics Card #1 AMD Radeon RX Vega 7 Graphics Card #2 nVIDIA GeForce GTX 1660 Ti 6GB (Samsung VRAM) - OC'ed & UV 2010Mhz Core Clock / +582Mhz Memory Clock Sound Card Realtek ALC256 @ AMD K17.6 - Realtek Audio with DTX:X Ultra Monitor LM156LF-2F03 Storage #1 WDC PC SN530 SDBPNPZ-256G-1002 (256 GB, PCI-E 3.0 x4) Storage #2 ST1000LM035-1RK172 (1 TB, 5400 RPM, SATA-III) HDD + SHGP31-500GM-2 500.1 GB CPU Cooler Stock Cooler Case Non Power Supply ASUS Power Brick 180W Keyboard ASUS TUF Keyboard with RGB Backlit Mouse ASUS ROG Sica Optical USB Gaming Mouse Headset ASUS Cerberus Gaming Headset Mouse Pad Generic Mouse Pad Headset/Speakers Anker Soundcore Life Q20 Hybrid Active Noise Cancelling OS Windows 10 21H2 - Lite [Modded by me] Network Router - Accessory #1 - Accessory #2 - Accessory #3 -
- Join Date
- May 2017
- Reputation
- 45
- Posts
- 37
couldn't thank you enough ! really appreciate it.
12-23-2020 03:09 AM #10
harrisonchu88 PC Specs Motherboard ROG MAXIMUS X HERO (WI-FI AC) Processor Intel Core i7-8700K Memory (part number) F4-3200C16D-16GTZR Graphics Card #1 EVGA - GeForce GTX 960 4 GB Monitor Asus VG248QE 24" 144 Hz Storage #1 Samsung - 960 EVO 250 GB M.2 Storage #2 WD Caviar Black 4TB 3.5" 7200RPM CPU Cooler Corsair - H115i AIO Case Corsair - 750D ATX Full Tower Power Supply EVGA - SuperNOVA G3 850 W 80+ Gold Keyboard Razer - BlackWidow Chroma V2 Mouse Logitech - G502 Proteus OS Windows 10 Pro 64 Network Router Netgear Nighthawk X4S R7800
- Join Date
- Nov 2018
- Reputation
- 10
- Posts
- 1
First of all, thank you for all the great threads here!
I'm currently facing some issues with my ethernet adapter (described here) and hoping to seek some clarification, as SE and Discord did not bring much more clarification. I did get a singular reply solely regarding the question of whether all Maximus X Hero Wifi-AC boards come with the same on-board network adapters here:
Discord Convo
From this, I inferred that all Maximus X Hero Wifi-AC ship with Intel i219-V Ethernet Adapter along with Intel WIfi and BT adapters. A while back, due to an update that broke Miracast functionality, I had read at the time that this was due to Intel pulling the plug on interoperability, and as a result I had replaced the driver with one for "Realtek 8822BE Wireless LAN 802.11ac PCI-E NIC", which indeed restored Miracast functionality. Somewhere in-between, the ethernet port stopped working though, and due to various circumstances I didn't notice until much later on, leading to my current quandary of wondering whether or not the loss of function is in some manner caused by the above mentioned change, or a completely unrelated matter.
I've made a presumption that perhaps I might need to change all my networked adapter drivers (WLAN, ethernet, and BT) to Realteks', but wasn't certain whether or not this was the case, and my searches were inconclusive to my limited understanding. Since your threads consolidate multiple model series together, I also realized I should not just simply assume these are beyond any doubt compatible with my hardware, and thought it prudent to first post and check. As such, I'm here hoping to get some clarification as all my attempts thus far have not remedied the issue and I'm becoming increasingly uncomfortable with continuing any potentially detrimental actions borne of my poorly informed decision making.
Thanks in advanced for any feedback!
