Results 1 to 2 of 2
    ROG Member Array
    Dec 2013
    5
    Rog Maximus VI CMOS Battery change
    need Information about the Cmos Battery which one that is 3 V? 5V?
    How i proceed with the Armour do i have to strip all over or is there a better Solution for this?
    Thx
    New ROGer Array RedSector73 PC Specs
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    695
    Most Bios Battery are a CR2032 <-- This is specification of the battery.
    Your motherboard is this.
    It is 3 volts lithium battery. Typically lasts 5-10 years unless you turn off computer at mains power each night, in which case that time can be low as 2-4 years.
    I had wondered why you were asking given they are easily visible on most motherboards, but yes yours is under the armour (yes, you have to remove it). You will find it below the cpu to the left.
    Buy a name brand CR2032 a cheap one can give no end of special problems. When motherboard start doing anything funky this is first thing to change out and the last thing a lot of people think of when dealing with random strange events starting on there ageing computer.
Tags for this Thread
