Results 1 to 4 of 4
    ROG Enthusiast Array andlaw PC Specs
    andlaw PC Specs
    MotherboardRAMPAGE VI EXTREME ENCORE
    ProcessorIntel® Core™ i9-10900X @ 5GHz AC 1.359v
    Memory (part number)CORSAIR Dominator Platinum 32GB (CMD32GX4M4B2400C10)
    Graphics Card #1EVGA GeForce RTX 2080 SUPER FTW3 HydroCopper
    MonitorASUS VG248QE 24" 144Hz
    CPU CoolerCustom Water Loop [Alphacool/ EKWB]
    CaseLian Li 011D XL-X
    Power SupplyCORSAIR AX1200i Platinum
    Keyboard Logitech G910 Orion Spark
    Mouse Razer DeathAdder Black Edition
    Headset Audio-Technica M50X Professional
    Mouse Pad ROG Sheath XL
    Headset/Speakers Samsung H551 soundbar
    OS Windows 10
    Network RouterLinksys WRT1900ACS
    Accessory #1 Mayflower Objective2 w/ ODAC - Rev. B Combo
    andlaw's Avatar
    Jun 2015
    20
    74
    Exclamation ROG R6EE dimm.2 LED
    Hello, I recently installed and have been trying to figure out how to disable the red LED's in my ROG dimm.2 module, supplied with my Rampage 6 Extreme Encore motherboard. I figured with having a custom loop, using the dimm.2 module would be the best option adding in this storage drive.. but this LED that shows when a drive is installed is absolute garbage! I did a search on here and google and wasn't able to turn up much results, so if any one has insight on this matter it would be greatly appreciated as I can't see why they would have a static red LED that can't be disabled or changed colors when everything today is RGB. (why Asus WHyyyy) Thanks in advance!
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    264
    A couple of coats of black nail polish or paint.
    andlaw PC Specs
    OS Windows 10
    andlaw's Avatar
    Jun 2015
    20
    74
    Quote Originally Posted by G75rog View Post
    lol I will use a thermal pad to cover it before I go that route. .. but I still don't see either to be a reasonable solution. Prior version/ had jumpers to disable/enable the LED, but this neither has them built into the module or on the motherboard. Even if the color isn't changeable, it should be an option to disable (whether being an option in software or using jumpers like in the past).
    another bull**** part from Asus it seems, the fan extension is junk as well~
    andlaw PC Specs
    OS Windows 10
    andlaw's Avatar
    Jun 2015
    20
    74
    well.. hopefully there is a fix but for the meantime I added a small strip of thermal pad to cover the LED. out of site out of mind lol.
