Results 1 to 7 of 7
    New ROGer Array
    Mar 2019
    2
    Angry GX701GX keyboard not working after firmware update
    I received an update notification from MyAsus yesterday telling that I need to update the KB Firmware update tool V2.2.4. However, after running the firmware updater my keyboard is now dead. The keyboard does not work in either Windows or Bios. I guess this is some kind of firmware problem.
    I tried to find KB Firmware update tool V2.2.4 on the support website but I failed. The online chat service asks me to reinstall windows to solve a firmware problem which is totally bull****.
    Anyone having the same problem please leave a comment under this thread and let's see if there is a solution. I don't want my 3k pounds laptop becomes useless trash.
    New ROGer Array
    May 2020
    1
    Contacted support and they sent me a file via email and now the issue is fixed.
    New ROGer Array
    May 2020
    1
    Same thing happened to me with my GX701GWR, after digging a bit deeper I've found the hotfix tries to update the firmware for the recent BIOS 308 update, so if you didn't manage to flash it to 308 it will BSOD and brick your keyboard.
    And of course MyAsus doesn't even bother to check nor does the firmware update tool what bios the notebook is running which is telling how little though asus puts in their software.
    Support was essentialy clueless about the issue so I've filed for RMA.
    Moderator Array
    Feb 2019
    13
    561
    Dear all,
    Would you be so kind to PM me your SN?
    I have reported this issue and would like to have more information about it.
    Thank you so much.
    New ROGer Array
    Nov 2019
    3
    Keyboard issue
    Quote Originally Posted by Back Pain View Post
    Can you please send me the link? Having the exact same issue. Some keys are not working.
    Thanks
    New ROGer Array
    Sep 2017
    3
    Has anyone solved the problem? Exactly the same situation with my gx701gv. The keyboard does not work at all, neither in Bios, or windows, only the touchpad.
    My s/n is K2NRCV021120708A
    My notebook become useless becouse of Asus mistake... Nice.
  7. #7
    New ROGer Array
    Sep 2017
    3
    I found solution for All GX701 Notebooks.
    After 2 days of suffering, I found a solution.
    After resetting win10, myasus prompted me to re-download the keyboard update, but the update was failing.
    I found a folder with a log file and my problem was:
    Tool Version : 2.2.4
    Product Name : GX701GV
    [Initialize] Start Flash : 20210103203630
    [Initialize] GetKBType : 0
    [Initialize] UnReg LightingService
    [Initialize] Battery Power Level : 100
    [Initialize] GetASUSDevice fail
    [Initialize] GetITEDevice
    After that I decided to find the original installation file for the firmware, which is located in the C/ProgramData/Asus/ASUS System Control Interface/AsusSoftwareManager/2 folder and is deleted immediately after an error in myasus.
    In the original file, I found the keyboard firmware files. Then I solved the problem that stopping flashing process with error "[Initialize] GetASUSDevice fail".
    Solution was wery simple, I downloaded KBFWUpdateTool_v1.0.5 and and moved the update file F0NK1100.GX701GV.308.bin to KBFWUpdateTool_v1.0.5/fw folder.
    Then just run ROGKBFWUpdateTool.
    END
    All files you can download on my google drive https://drive.google.com/file/d/1lS0...ew?usp=sharing.
    P.S. I like ROG notebooks, but i hate asus support and asus suftware updaters!
Tags for this Thread
