Results 1 to 5 of 5
05-19-2020 11:10 PM #1
- Join Date
- May 2020
- Reputation
- 10
- Posts
- 17
new build question, Motherboar has 1 20 pin USB connector and the Case has 2
The MB is a Asus ROG Crosshair VIII Hero (WI-FI)
The Case is a ASUS Strix Helios GX601.
The case has 5 front panel USB ports so the case has two 20 pin connectors and the odd one is the new USB 10 gig port so the odd one is covered by the connector on the motherboard. The question I have is what are the options for the case having 2 20 pin USB cables and the motherboard only having 1 20 pin connector? Are there adapters for this?
I know there are plenty of USB port on the back but that's back behind the desk and having the ones in the front is more convenient. Having 2 ports on the front that don't work kind of sucks.
DB
05-20-2020 12:34 AM #2
pndiode PC Specs Laptop (Model) ASUS G752VL-DH71 Motherboard ROG Maximus IX Extreme Processor I7-7700K Memory (part number) G-Skill F4-3600C19Q-32GTZRB Graphics Card #1 ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block Graphics Card #2 ROG Matrix GTX 980TI -P-6GD5 Bitspower Water Block Monitor SAMSUNG S22D300HY (2 ea) Storage #1 WD Black SN750 1TB Storage #2 WD Blue 4TB (4 ea) CPU Cooler EK PE 360 (Top), PE 240 (Front), and Xres 100 Elite Case ROG Strix Helios Power Supply ThermalTake Toughpower 1200W Keyboard Cerberus Mouse Logitech MX Master S2 Headset ROG Strix Fusion 300 Mouse Pad Generic Headset/Speakers Bose Companion 3 Series II OS Win 10 Pro 20H2 Network Router Generic Accessory #1 ROG Aura Terminal Accessory #2 ROG 10GB Express Accessory #3 Corsair ML140 (4 ea), Corsair ML120 (3 ea)
- Join Date
- Jan 2016
- Reputation
- 10
- Posts
- 226
05-20-2020 01:04 AM #3
- Join Date
- May 2020
- Reputation
- 10
- Posts
- 17
I think that's it!
Thanks,
DB
08-30-2020 12:02 AM #4
- Join Date
- Feb 2020
- Reputation
- 10
- Posts
- 1
Hello
I have built my first ROG X570 hero 8...At the bottem their are 3 USB ports at the bottem of the board..Now my caSE A THERMATAKE lVl20 gt the cables were able to go right in...Now on my water pump it looks just like the pic you posted only the others had some kind of a sleeve that was able to just plug right into the board..The way yoiur pic aka my water pump looks just like your pic minuse that sleeve to plug it in..Where do I get the sleeves from..I have it so close to hooking up but cant find where to buy those sleeves...Thank you..davidpoulson618@gmail.com
09-05-2020 07:16 PM #5
that pic is taken from internet, and for geting "sleves" like that you have to make it your self ( paracord for example ) witch means you have to unmount the cables from the connector block where they are attatched in.
NB! NB! mess it up and you void warranty NB! NB!
https://youtu.be/H5SLtnBNAsA
