Results 1 to 7 of 7
    New ROGer Array
    May 2020
    3
    G531gt weird popping sound issue
    I bought a g531GT about a week into owning the laptop there has been a weird popping sound from the speakers(?) it happens at random and oddly enough it also occurs when moving the mouse or the touchpad or even typing . I have reinstalled the sound drivers and updated every driver i could think of. yet the popping noises still persist. Anyone have any ideas what to do about this ?
    ROG Guru: Blue Belt Array
    Nov 2012
    75
    765
    If mine, I would return the laptop to the seller and ask for a replacement/refund.
    If seller provides no solution, then I would return the laptop to ASUS for repair/replacement.
    Good Luck
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    New ROGer Array
    May 2020
    3
    Quote Originally Posted by jdfrench3 View Post
    Good Luck
    I think I may do that. however unfortunate. Thank you for your opinion in this
    Moderator Array
    Feb 2019
    13
    561
    Hello aaassddffgg,
    May I have a record of the sound?
    Does the sound come out on headphone?
    Thank you so much.
    New ROGer Array
    Jul 2020
    3
    Hello sorry for late wieving i know your problem it happens to me actually. It's not coming from speaker or hard drive, it comes from your processor. It's a common problem in new 9th and 10th generation processors. To get rid of that you just have to open your power management menu and then customize all of your power plans then lower your maximum cpu usage about %5 its gonna solve it. If it's not i don't know what to do
    New ROGer Array
    Dec 2019
    2
    Quote Originally Posted by aaassddffgg View Post
    Did you got any solution to that weird popping sound?
    It's happening with me too on random interval!
    Whenever I restart my laptop, that sound persists and on restarting for about 2-3 times solves the issue.
    But, this is not the fix, I am searching for one.
    If you have any, please let me know!
    Thanks in advance!
  7. #7
    New ROGer Array
    Aug 2020
    I had a similar issue.
    I have a corsair mouse which uses icue software to control it.
    The thing is the icue is broken and it constantly turns the gpu on and off. It can't enter standby.
    What follows are huge spikes in system latency creating very audible pops from the speakers.
    Installing older version of icue software fixed the issue.
    Do you guys have a icue app by any chance on your pc?
