pci-e /w gpu running at x4
LarsTee
Hello everybody.
I have read many articlesand posts here and heard their solutions, tested them, but w/o any success.
For four days now I've been sitting in front of the computer and can't find a solution ...
In advance:
i7 6700k 4.0 GHz
Asus maximus extreme viii
evga gtx 1660 xc ultra
32 GB hyperX fury 2666 MHz (hx426c15fbk4/32)
corsair h60
evo 860 250 gb sata 6 (out now)
evo 960 250 gb m.2
bq dark power pro 10 750w
(None of them were overclocked manually during the tests)
I tryed...
- Bios update although the current version was already ahead - cmos reset via switch and new bios update with latest vers.
- switched to the third PCI-E slot (sli/cf)
- put in one of my old AMD R 6870 into the first PCI-E slot
- on power supply switched VGA 1 to VGA 2 (... helplessness) - - run it with one single RAM
- (SA) graphic configuration primary display Auto>peg
- starting w/o ssd
- the interface cleaned several times
- PCI-E slots activated and deactivated by Switch on mobo
- cried a little in between
- removed old SSD, added new one
Im thankful for any help...
https://ibb.co/vDSbM0S
https://ibb.co/DrjQkNt
https://ibb.co/NVw8jMR
https://ibb.co/0C6mKjs
https://ibb.co/xDz3xTJ
Best regards,
Lars
AnimalUK
Although i don't have an answer for you i can say that as of today im stuck with a similar problem where my gfx card is now stuck at 8x where as before it used to be x16 and i have no idea as nothing has changed.
here to hoping someone reads and has a solution!
oh also make sure u dont have thermal paste on the under side of the cpu !!!!
clean the underside of the cpu itself!!!
make sure there is contact between cpu and motherboard!!!
AKBAAR
am having similar issue lately when i moved my pc in my car, i think i have bent the motherboard cpu socket pins!!!!
you have motherboard cpu socket pins bent!!! please check them and fix the pins on the mothboard
my pc is runing 2x HAHAHAH
85229
