Results 1 to 6 of 6
    ROG Enthusiast Array
    Dec 2017
    25
    Does the G752 work with a Samsung 860 Evo?
    I upgraded my G752VT with a Samsung 850 EVO, 2 years ago, and was looking to get even more space, and saw that the 860 has replaced it now in stores.
    Just wondering, if this is still compatible. I am assuming so, but I want to be sure, before I spend the 1k on it.
    2nd question, Let's say later down the track I buy a Rog Scar 3, can I install this same 860 Evo into that machine too?
    ROG Guru: Green Belt Array
    Nov 2012
    67
    719
    What version Samsung 850/860 Evo are you referencing? The m2 or SSD model?
    Both the Samsung 850/860 Evo SSDs are SATA III.
    Both the Samsung 850/860 Evo Internal SSDs are m.2 drives.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    Dec 2017
    25
    Quote Originally Posted by jdfrench3 View Post
    The SSD's.
    This is what I have in now: https://www.scorptec.com.au/product/...r_pricing=true
    This is what I was looking to upgrade to: https://www.scorptec.com.au/product/...r_pricing=true
    Nov 2012
    67
    719
    Ok, SSD platform. Both the 860 and 850 EVO are SATA III interface. The problem you might encounter is the actual size of the different SSDs That 4TB 860 EVO is 11mm thick. From what I can read, the space in the ASUS Scar III laptop is 9.5mm.
    Good Luck
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,152
    Quote Originally Posted by Padraigo View Post
    The SSD's.
    Yes there is no difference between the 850 and 860 2.5 SATA SSD Physically so its a direct replacement. The 860 will have better Write speed and boot speed
    According to the advertisement on Amazon the 4TB is 7mm also.
    Also on the Samsung Specification page also shows all versions of the 860 2.5 SATA 2.5 including the 4TB to be 7mm https://www.samsung.com/semiconducto...nsumer/860evo/
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    Dec 2017
    25
    Thanks guys.
