Results 1 to 6 of 6
    New ROGer Array
    May 2020
    4
    What does this mean ? pls active users give review
    I plan on buying a new Asus ROG motherboard and in all the user mannul i find this instruction. Is this a serious instruction ? would i be able to connect, joystick, mouse, vr headmount , printer, phone to the usb 3.1 and 3.1 gen 2 ports? I checked this with ASUS ROG Strix B365-F gaming mobo but later found this message in many mother boards'. is this a permanent issue of is there a bios update or application with which i can use USB 3.1 Gen 2 ports for connecting printer, joystick etc? I dont want my investment to go in vein. i have many usb peripherals that i need to connect parallely and i do need all those p
    New ROGer Array
    May 2020
    4
    Exclamation USB issue, is there a fix for this?
    ROG Member Array Rolda PC Specs
    Rolda PC Specs
    MotherboardROG Crosshair VII Hero
    ProcessorRyzen 7 1700
    Memory (part number)2x Kingston HyperX KHX3200C18D4/8G
    Graphics Card #1ROG STRIX RX5700XT O8G GAMING
    MonitorROG Strix XG49VQ
    Storage #1Samsung NVMe 970 EVO 250GB
    Storage #2Seagate ST3000DM007 3TB
    CPU CoolerZalman CNPS9X Optima
    CaseASUS TUF GAMING GT501
    Power Supplybe quiet! Power Zone 1000W
    Keyboard Roccat Ryos MK Pro
    Mouse Roccat Tyon
    OS Win 10 Pro x64 1909
    Sep 2011
    11
    Yes.You can connect anything (joystick, mouse, vr headmount, printer, phone) to usb 3.1 and 3.1 gen 2 ports.
    New ROGer Array
    May 2020
    4
    Exclamation
    Thank u , do i need to update bios or install any software to that? Have u checked it personally ?
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,593
    That simply means that on connecting external drives, they can only be used as storage..not boot drives.
    Of course, you can connect any other usb device to them
    ROG Guru: Orange Belt Array Super Gnome PC Specs
    MotherboardROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula
    ProcessorIntel® Core™ i9-9980XE / AMD 3950x
    Memory (part number)Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH
    Graphics Card #1Asus 2080 Turbo / Asus 2080 ti Turbo
    Graphics Card #2Asus 2080 Turbo / Asus 2080 ti Turbo
    MonitorJAPANNEXT JN-VT500UHD 4K 50-inch LCD
    Storage #1Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500
    Storage #2Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2
    CPU CoolerROG Ryujin 360 / NZXT Kraken X62
    CaseThermaltake View 71 TG / Thermaltake View 31
    Power SupplyCORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt
    Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2
    Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
    Mar 2019
    290
    USB stuff that is older can be used in these ports. It is backwards compatible. But if you want the best performance, buy the newest stuff so that you can take advantage of the speed. That is what it means.
    Whether or not devices that require higher speeds can be used in older ports is a whole other story. Newer devices may not work properly in older ports though--you have to check the specs.
    That is my take on it, anyhow.
    As for what is meant by "USB 3.1 Gen1/Gen 2 can only be used data storage only" ??? The English is poor as you should only use the word "only" once--first off. And USB ports are never for "data storage" only. USB ports can always be used for a variety of things. Hence, it is a puzzle I cannot answer, but see all kinds of that gobbledygook in such manuals with no idea of the meaning. Sometimes you need to translate--kind of like when you read Shakespeare. It is often pointing to something pertinent, but will remain a mystery and/or requires intuition and/or experience.
Tags for this Thread
