Results 1 to 6 of 6
    ROG Member Array
    Dec 2013
    15
    Connecting Corsair H100i RGB Platinum to Rampage VI extreme encore
    Hi everybody
    My configuration is R6EE, core i9 10900x, corsair H100i RGB PLATINUM and i'd like to know your feeling about how to connect the H100i to the motherboard?
    Here is what i've done :
    Pump sata to sata connector, pump to cpu fan, the 2 fans to the pump througt the Y wire.
    On the mother board there are 2 pump connectors that i didn't use but maybe it is not the best solution.
    If you are clever about that question please feel free to tell me what I should do.
    At the moment my cpu core temp in idle mode is 29°c (7 °c above ambiant temp). When i tried to use sisoft sandra to test the PC the core temp jumps to 102°c (i shutdown in hurry) and it seems that there was no cooling at all!
    In normal mode the core temp is near 45°c (games etc...).
    Thanks in advance
    François
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    265
    Did you install the USB cable and software?
    ROG Enthusiast Array andlaw PC Specs
    andlaw PC Specs
    MotherboardRAMPAGE VI EXTREME ENCORE
    ProcessorIntel® Core™ i9-10900X @ 5GHz AC 1.359v
    Memory (part number)CORSAIR Dominator Platinum 32GB (CMD32GX4M4B2400C10)
    Graphics Card #1EVGA GeForce RTX 2080 SUPER FTW3 HydroCopper
    MonitorASUS VG248QE 24" 144Hz
    CPU CoolerCustom Water Loop [Alphacool/ EKWB]
    CaseLian Li 011D XL-X
    Power SupplyCORSAIR AX1200i Platinum
    Keyboard Logitech G910 Orion Spark
    Mouse Razer DeathAdder Black Edition
    Headset Audio-Technica M50X Professional
    Mouse Pad ROG Sheath XL
    Headset/Speakers Samsung H551 soundbar
    OS Windows 10
    Network RouterLinksys WRT1900ACS
    Accessory #1 Mayflower Objective2 w/ ODAC - Rev. B Combo
    andlaw's Avatar
    Jun 2015
    20
    74
    Quote Originally Posted by francoistoen View Post
    Hi everybody
    Thanks in advance
    François
    Hi, while I have the Encore.. I do not have that CPU cooler, but the directions for it are pretty straight forward. from the pump (block) on the H100i you should have a Sata power cord, and a Y-split for the fans. You connect the sata from the pump to a connection via PSU., you connect your two fans from the radiator to the pumps Y-splitter, and the last thing to do should be plugin the USB connection which gets plugged into a USB 2.0 connector on the mobo. From there, you have power.. fans.. and 'communication' from the pump to the motherboard via USB. If you didn't have any active cooling... the temperatures would rise and rise from the moment you start the PC until it detects too high of temp and auto shuts down. If you are getting and keeping 45c temps while playing.. its operating as it should~ If you are running a benchmark and stress test, and are reaching 100c temps... its obvious the cooler isn't up for the task. The 10900X is pretty toasty at 165w (normal conditions 3.7 frequency)... and upwards to 300W while being overclocked. You might try configuring a stronger fan curve or higher static RPM for your fans to keep cooling in check. .. ... but it sounds like you only experienced the issue while benchmarking?!
    ROG Member Array
    Dec 2013
    15
    Quote Originally Posted by G75rog View Post
    Yes i did it. I looked at the software and then unplugged it because it use the only one USB2.0 connector of the motherboard. I prefer to get 2 usb ports at the front panel of the computer. At that time i'm lokking for an adaptator to plug the pump on an usb 3 internal connector.
    I don't know what exactly does that sofware .
    Thanks for your reply
    ROG Member Array
    Dec 2013
    15
    Quote Originally Posted by andlaw View Post
    Hi thanks for reply.
    I did what you have said for connecting the H100i to motherboard. But there are two questions :
    Is the usb link an option to run the sofware ICUE or is the link mandatory for the pump to work?
    Then what is the use of the connectors W_PUMP+2 and W_PUMP+1 on the motherboard?
    If you have any idea about those questions feel free to share.
    François
    ROG Member Array
    Dec 2013
    15
    Quote Originally Posted by MoKiChU View Post
    The USB port is only for management via iCUE and is not necessary for the pump of your AIO watercooling to work.
    Regarding the W_PUMP+1 & W_PUMP+2 connectors, they are used in the case of custom watercooling (not AIO, which use the AIO_PUMP connector).
    OK for the fist answer. So I don't need to use it really.
    For the second answer you talk about the AIO_PUMP connector. Is that connector on the pump itself or is it on the motherboard? I can't find it on the motherboard.
    If it is pump side where to plug it on motherboard? I plugged it on CPU-FAN connector is it right?
    Thanks
