Results 1 to 1 of 1
    New ROGer Array
    Jul 2019
    6
    Rampage VI Extreme Encore default uncore voltage?
    Hi there, I have Rampage VI Extreme Encore and I need +425 on the uncore to be able to get my oc stable.
    Auto will set any memory oc to +485, which I believe the max offset which is still safe.
    My question what is the +0 offset value?
    HWinfo only shows the offset value but not what actual value it corresponds to.
    Looking at other boards like EVGA x299 Dark it seems it is 0.95v however it may have different default value than Asus considering the dark default VCCIN is 1.7v while RVIEE has default of 1.85v.
    Thanks!
