Results 1 to 8 of 8
    New ROGer Array MDG73 PC Specs
    MDG73 PC Specs
    MotherboardASUS Z390-E Gaming
    Processori7-9700F
    Memory (part number)Corsair Vengeance Pro RGB 32GB 4x8
    Graphics Card #1EVGA RTX 2070 Super 8GB
    Sound CardOnboard
    MonitorLG 27GL850
    Storage #1Samsung 970 EVO Plus M.2 500GB
    Storage #2Samsung 970 EVO Plus M.2 1TB
    CPU CoolerCooler MAster Hyper 212 Black
    CaseLIAN Li Lancool II
    Power SupplySeasonic SS-760XP2
    Keyboard Razor Ornata Chroma
    Mouse Razor Death Adder
    Headset Razer
    Mouse Pad Razor
    OS Window 10 Home 64bit
    Network RouterNetgear Nighthawk X4S AC2600 Model R7800
    May 2020
    14
    CPU staying locked in turbo (x45), not downclocking when idle
    Hello all,
    I am having an issue where the CPU 9700F is not downclocking when idle. Any assistance would be greatly appreciated. I have the balanced power profile selected in windows. Most of the BIOS settings are on auto for CPU. Not sure what is keeping it revved up all the time.Click image for larger version.
Name:	Cores locked to 45x.jpg
    Boy do I have a lot to learn. I'm not sure what the (perf #....) is suppose to be but I finally see the actual core speeds right below that shows its downclocking. This whole time I was looking at the wrong things :P
    But why is the voltage staying high? Shouldn't it drop down too?
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,596
    Looking at minimum and maximum columns, it looks like the CPU is downclocking and downvolting
    However the "current" column shows the CPU maxed out....at the time you took the screenshot...a transitory coincidence? or something running in the background?
    MDG73 PC Specs
    Processori7-9700F
    Sound CardOnboard
    MonitorLG 27GL850
    Headset Razer
    Mouse Pad Razor
    May 2020
    14
    Yes, that is what I am talking about. The current remains pegged out at 45x. I don't know what could be running in the background causing this unless its one of the following: Corsair iCUE software, MSI afterburner, Samsung Magician, razor central or razor synapse, intel driver and support assistant. I guess I could disable those one at a time to find the culprit. But I have never had this issue before.
    MDG73 PC Specs
    Processori7-9700F
    Sound CardOnboard
    MonitorLG 27GL850
    Headset Razer
    Mouse Pad Razor
    May 2020
    14
    Talking
    I went looking through the task manager and found that Windows defender smartscreen is using up to 26% of my cpu constantly. This was the cause for the cpu to be constantly pegged out. I stopped the service and then restarted it and everything seems to be working as it should now. Thank you for suggesting that something could be running in the background. That spurred me into checking that out. Thanks!!!!
Name:	Fixed Temp issue.jpg
    MDG73 PC Specs
    Processori7-9700F
    Sound CardOnboard
    MonitorLG 27GL850
    Headset Razer
    Mouse Pad Razor
    May 2020
    14
    Well I thought I fixed it. Now its back to a static 45x. Ugh!!!
    MDG73 PC Specs
    Processori7-9700F
    Sound CardOnboard
    MonitorLG 27GL850
    Headset Razer
    Mouse Pad Razor
    May 2020
    14
    Ok so if anybody can assist here I would appreciate it. The only way can get my computer to downclock during idle is to use the power saver profile. Then it behaves normally. When viewing HWinfo64 though some of the core effective clock readings and other various readings (VR VCC (SVID), VRM, C state residency readings appear to grey out and come back but still continue to read. Click image for larger version.
  7. #7
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1System : SSD Samsung 960 EVO 256GB
    Storage #2Games : SSD Corsair MP510 240GB | Data : SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 2004/VB/19041.x
    MoKiChU's Avatar
    Aug 2013
    195
    373
    Try by disabling ASUS MultiCore Enhancement (setting in Auto by default) in Ai Tweaker tab (Advanced Mode) in your BIOS/UEFI > F10 (Save & Restart).
  8. #8
    MDG73 PC Specs
    Processori7-9700F
    Sound CardOnboard
    MonitorLG 27GL850
    Headset Razer
    Mouse Pad Razor
    May 2020
    14
    Thank you for the suggestion, I appreciate you taking the time to reply. I did try that on a few occasions, but it didn't seem to work. I ended up reinstalling windows and that took care of the issue for the time being. I'm assuming a file got corrupted somewhere along the lines and I just don't have the expertise to investigate it thoroughly.
