3950X Base clock @ 3400 MHZ not 3500 MHZ
svan71
I have bios 1302 installed and I am not overclocking my cpu but for some reason my processor is running at 3400 mhz base not 3500 and I have no idea why. Its boosting fine but at idle I'm 100mhz off on all cores. Cpu z as well as hwinfo show my multiplier at 34.
Any ideas?
Veovis
No idea if you're using Windows, but perhaps Windows power settings? I had a bottle neck for about 2 weeks until I realized there was an "AMD RYZEN HIGH PERFORMACE" plan buried in the Power&sleep section (additional settings) of the settings window.
As for the base clock? You can tweak that manually in the BIOS/AI Tweaker if the multiplier is stuck at 34, assuming you're on an X or B motherboard.
Veovis wrote:
No idea if you're using Windows, but perhaps Windows power settings? I had a bottle neck for about 2 weeks until I realized there was an "AMD RYZEN HIGH PERFORMANCE" plan buried in the Power&sleep section (additional settings) of the settings window.
Bingo ! thanks, it seems the Balanced plan actually lowers the multiplier.
