Can't uninstall AI SUITE 3 - Help
joppiano
Dear peeps.
I am currently not able to uninstall AI SUITE 3. Various errors is popping up upon trying to uninstall.
I have used CCLEANER to remove all ASUS registries.
I have used the AI SUITE 3 Cleaner posted by Raja.
The AI SUITE 3.exe got removed upon using the cleaner from Raja, but the AI SUITE 3 is still listed in Add/Remove programs, and I cant uninstall it.
Various issues pop up upon trying to uinstall. Even without trying to uninstall, I am getting weird related popups, such as this:
https://i.gyazo.com/ce9ce414803cfa55c8540785c8e48f2a.png
https://i.gyazo.com/6bee8e2bfbba15f98b41ce1086a3d9d5.png
Anyone able to help me resolve this issue?
Best regards
Jesseinsf
Is AI Suite the only Asus product installed on your system?
Yes. Aside from various ASUS drivers i pressume.
No matter what I do, I simply can't uninstall nor remove it.
Any suggestions?
Any suggestions?
Have you tried reinstalling it with a newer version and then uninstall it again from control panel? Try that first. If it doesn't work then I would use an application like Revo Uninstaller. I not only use Revo uninstaller to uninstall apps, I also use it monitor an application's install process so it has a more thourough uninstall clensing.
