Results 1 to 6 of 6
    ROG Member Array daydr3am3r PC Specs
    daydr3am3r PC Specs
    Laptop (Model)ASUS ZenBook Pro UX501VW
    MotherboardROG MAXIMUS XI HERO (WI-FI)
    ProcessorIntel® Core™ i7-9700K Coffee Lake, 3.60GHz
    Memory (part number)DDR4 Corsair Vengeance 4x8GB 3200MHz
    Graphics Card #1ASUS GeForce® GTX 1080 Ti STRIX, 11GB GDDR5X
    MonitorAsus ROG PG278QR
    CPU CoolerNoctua NH-D15
    CaseBe quiet! Dark Base 900, FullTower
    Power SupplyCorsair HX750i, 750W, 80 PLUS Platinum
    Keyboard SteelSeries APEX 350
    Mouse SteelSeries Rival 700
    Headset SteelSeries Arctis 7
    Headset/Speakers Microlab FC530U
    OS Windows 10 Pro
    Network RouterAC1750 TP-Link Archer C7, Gigabit, Dual Band
    Oct 2018
    8
    ASUS Sonic Studio 3 / Realtek HD Driver Sound Issue
    Hi everyone,
    1 or so week ago I started having problems with Sonic Studio 3. Specifically, it started crashing randomly and no matter what changes I made, nothing worked.
    I reinstalled Sonic Studio 3 (currently I have v3.16.9.0 installed) and Sonic Radar 3 but nothing changed. I tried reinstalling the audio driver, but again, nothing changed.
    Moreover, now in some games and apps, when I use the speakers (I have multiple audio devices) the sound is incredibly low. There are games where I have to tune up the sound to max and still I barely hear anything.
    Also, if I try to activate the Audio Enhancements in Windows, the output automatically changes to headphones, even though technically the speakers remain selected.
    Any ideas? I am using Windows 10 Pro x64, up to date (2004) on this:
    Motherboard: ROG MAXIMUS XI HERO (WI-FI)
    Processor: Intel® Core™ i7-9700K Coffee Lake, 3.60GHz
    Memory (part number): DDR4 Corsair Vengeance 4x8GB 3200MHz
    Graphics Card #1: ASUS GeForce® GTX 1080 Ti STRIX, 11GB GDDR5X
    Monitor: Asus ROG PG278QR
    CPU Cooler: Noctua NH-D15
    Case: Be quiet! Dark Base 900, FullTower
    Power Supply: Corsair HX750i, 750W, 80 PLUS Platinum
    Keyboard: SteelSeries APEX 350
    Mouse: SteelSeries Rival 700
    Headset: SteelSeries Arctis 7
    Headset/Speakers: Microlab FC530U
    OS: Windows 10 Pro
    Network Router: AC1750 TP-Link Archer C7, Gigabit, Dual Band
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 64 bit 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    329
    580
    The "Enable audio enhancements" box (in Properties > Advanced tab of your outputs) should be ticked, otherwise you will lose the functions of SS3.
    You have an ASUS ROG SS3 motherboard, so :
    You need Realtek Audio Drivers (UAD - ASUS ROG SS3 MB) from the first post of this thread.
    Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
    daydr3am3r PC Specs
    OS Windows 10 Pro
    Oct 2018
    8
    Thanks for the help.
    I followed all the steps and I managed to get the sound to some acceptable levels. However, I now am in the same situation as I was before - SS3 was OK on first run but when I tried to change the profiles (Music, Movie, etc.) nothing changed.
    I closed it and when I tried to run it again I get the same error as before.
Name:	Annotation 2020-06-14 144215.png
    And some apps / games still have incredibly low sound.
    Any ideas?
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    329
    580
    Re-follow scrupulously the CLEANUP process then INSTALL process, but this time to prevent Windows Update from generating a drivers install conflict, disable your Internet connection from the start of the INSTALL process (before cleanup step) until the end of drivers install of the INSTALL process (after the restart). For the next drivers packages that I would release, you will can directly follow the UPDATE process.
    daydr3am3r PC Specs
    OS Windows 10 Pro
    Oct 2018
    8
    Quote Originally Posted by MoKiChU View Post
    Thanks again for your help and sorry for the late reply.
    I followed the steps provided but unfortunately the result is the same.
    Moreover, although not sure if related or not, now ASUS GPU Tweak stopped working and reinstalling it did not help...
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    329
    580
    Quote Originally Posted by daydr3am3r View Post
    You said : "1 or so week ago I started having problems with Sonic Studio 3"
    Has your SteelSeries Software been updated at that time ?
    Anyway, you may be have kind of conflicts with others devices/drivers/softwares, so in order to determine which one generates the conflict, try this :
    - Disconnect all the USB dongle peripheral devices.
    - Uninstall all the software of your headset/headphones/mic and/or peripheral devices which could contain audio modules like SteelSeries Engine Software or ROG Armoury (even if you installed the software for a device which is not audio).
    - Follow scrupulously your INSTALL process with cleanup step, but this time to prevent Windows Update from generating a drivers install conflict, disable your Internet connection from the start of the CLEANUP process until the end of drivers install of the INSTALL process (after the restart).
    If everything works after that, reconnect the USB dongle & Install the software of your headset/headphones/mic/peripheral devices one by one in order to determine which one generates the conflict then that you can report it to the adequate support service of the problematic device.
Tags for this Thread
